Runs for minutes at a time?? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-05-2011, 04:53 PM Thread Starter
So my 00 7.3 Excursion died on me today while driving about 35 mph. I turned off the key let it sit for about 45 seconds and then restarted.... Drove for about 1 min then it died again... this repeated several times... Once it dies all I need to do is let it sit for a few minutes and then it'll start again but will only run for a couple minutes and doesnt matter if its at idle or not. I replaced the fuel filter just because I had recently filled up but it didnt do any good. Any advice is appreciated since I'm about 400 miles away from home.
joker9r is offline
post #2 of 4 Old 02-06-2011, 07:14 AM
Quoted: 132 Post(s)
Feedback Score: 3 reviews
Does the tach needle move up slightly when cranking? Got a spare CPS to try?
Was there fuel in the fuel bowl and did it refill after the filter change?
Fuel - pump runs? Fuel refilling filter housing? Tank below 1/4?
NoRalPh is offline
post #3 of 4 Old 02-06-2011, 08:23 AM
goats's Avatar
Quoted: 2 Post(s)
Sounds like a classic CPS went out
goats is offline
post #4 of 4 Old 02-06-2011, 02:55 PM
classic CPS, turns off with no warning, happened on a truck i was driving a few times(not minee)
Dietoremain is offline
