Oil leak where could it be coming from? oil cooler o rings?? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-03-2011, 02:39 PM Thread Starter
snowmobiler7c's Avatar
I have a 2003 f250 7.3L with an oil leak. I beleive the leak is coming from the oil cooler but not 100% positive. Is there anywhere else on the driver side where it could possibly be leaking i know its not the valve cover for sure. It is really hard to see but i know its dripping on the front axle and blowing back while driving on the underbody by driver footwell. Also if it is the oil cooler does ford make a kit with all the seals and o rings?? thanks
mark
snowmobiler7c is offline
post #2 of 4 Old 03-12-2011, 02:04 PM
yes ford makes a kit with o rings. there are 2 black o rings and 2 green o rings. they run about $30 for the 4 0-rings. I dont have the numbers off hand but they do make them.
firefighter317 is offline
post #3 of 4 Old 03-12-2011, 02:15 PM
1C3Z-6C610-BA & 1C3Z-6K649-BA are the 2 part numbers for the o-rings. You need 2 of each part number (2 green o-rings and 2 black o-rings). They list for $4.89 and $11.79 each so around $30 for all 4 o-rings.
post #4 of 4 Old 03-12-2011, 03:08 PM
Kyle_KleinSS's Avatar
Dont for get the 2 gaskets as well
Early 99 F350 7.3 PSD Diy Intake,4 in TB straight pipe, 17* HPOP CCV Mod, Foil Delete, HPX, BTS VB, Coolant Filter, Autometer Boost, Pyro, Trans, TrueTrac, TC Lockup, EBPV Brake, Leveled, Tru Cool 4739
03 Cobra 530/550
97 Saturn SL1 - Sold
2000 Focus - DD
Kyle_KleinSS is offline
