TRUCK IS NOT MOVING UNTIL I GET HELP! - Ford Powerstroke Diesel Forum
post #1 of 56 Old 02-03-2011, 02:09 PM Thread Starter
Jonboywv12's Avatar
Send a message via AIM to Jonboywv12
okay guys like the title says, i am removing the turbo i got the driver and passenger side intercooler lines off, as well as all of the y-pipes. i have diconected the clamp on the down pipe, i just cannot get clamp off the back of the up pipe i need some suggestions like now!! i need the truck to be moving i also have the two bolts out of the pedistal so the clamp on the back is the only thing slowing me down. please help. i am trying to replace pedastal o-rings. thanks in advance
-Jon
Jonathan or Jon
2002 F-350
4" Banks turbo back exhaust.w/5" tip
4" Banks down pipe
Banks Big Hoss turbo waste gate
6" SKY JACKER
35" Nitto All-Terrains
TW chip 6 pos.
Banks Trans-Command shift kit
AFE STAGE II Intake
Gauges (boost, EGT)
102" whip antenna (guaranteed 100hp!
enough for fun!
Jonboywv12 is offline
post #2 of 56 Old 02-03-2011, 02:17 PM Thread Starter
Jonboywv12's Avatar
neeeeed heeeeelppppp!!!
Jonathan or Jon
2002 F-350
4" Banks down pipe
6" SKY JACKER
TW chip 6 pos.
AFE STAGE II Intake
Gauges (boost, EGT)
enough for fun!
post #3 of 56 Old 02-03-2011, 05:19 PM Thread Starter
Jonboywv12's Avatar
Exclamation
come on anyone???
Jonathan or Jon
2002 F-350
4" Banks down pipe
6" SKY JACKER
TW chip 6 pos.
AFE STAGE II Intake
Gauges (boost, EGT)
enough for fun!
post #4 of 56 Old 02-03-2011, 05:24 PM
assistant director
thbd77's Avatar
Good luck I have not messed with the turbo on one of these. I have had to beat the clamp off rusts together.
Name-Troy Lincoln
96 F-250 4X4 stroked xcab shortbed 5 speed
01 EXCURSION LIMITED 4X4 V-10 brute force intake dual exhaust
02 EXCURSION LIMITED 4X4 stroked ts 6 position 4" dp and duals hers now
06 F-250 4x4 6.0 auto lariat crew cab short bed Dads ride
thbd77 is offline
post #5 of 56 Old 02-03-2011, 05:30 PM Thread Starter
Jonboywv12's Avatar
so your saying the clamp could possibly be rusted to the up pipe??
Jonathan or Jon
2002 F-350
4" Banks down pipe
6" SKY JACKER
TW chip 6 pos.
AFE STAGE II Intake
Gauges (boost, EGT)
enough for fun!
post #6 of 56 Old 02-03-2011, 05:35 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Loosen it until you can get the "T" part of the bolt out of the clamp. Use a flat screwdriver and get it under the edge of the clamp and twist. It might take a little work but it should pop loose. You might have to do this in a couple places. The heating and cooling cycles cause the clamp to stick. It's not rusted.
dhanna6powerstroke is offline
post #7 of 56 Old 02-03-2011, 05:42 PM Thread Starter
Jonboywv12's Avatar
okay cause i have been going at it all afternoon! the nut is completely off of the clamp its just a free clamp there with the bolt in it. but okay i will try to get under it and move it around. that is the only thing that is holding the turbo down at this point correct?
Jonathan or Jon
2002 F-350
4" Banks down pipe
6" SKY JACKER
TW chip 6 pos.
AFE STAGE II Intake
Gauges (boost, EGT)
enough for fun!
post #8 of 56 Old 02-03-2011, 05:45 PM
Mod Newbie
Quoted: 20 Post(s)
Should be as long as the 2 bolts are out and the downpipe clamp is off
post #9 of 56 Old 02-03-2011, 05:46 PM Thread Starter
Jonboywv12's Avatar
yes i have the dp clamp off and the pedestal bolts out as well. should it be hard to get off? or should it just lift up?
Jonathan or Jon
2002 F-350
4" Banks down pipe
6" SKY JACKER
TW chip 6 pos.
AFE STAGE II Intake
Gauges (boost, EGT)
enough for fun!
post #10 of 56 Old 02-03-2011, 05:49 PM
Mod Newbie
Quoted: 20 Post(s)
It should lift right off but might take a little maneuvering to get it out.
