Bad IPR -- what are the symptoms - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-02-2011, 03:58 AM Thread Starter
Question Bad IPR -- what are the symptoms
Any feedback on what a sticky IPR would feel like on a 7.3? How would that affect the motor ?
Thanks , RB
XR-2001 is offline
post #2 of 11 Old 02-02-2011, 05:55 AM Thread Starter
Anybody ? ?
The reason I ask is this : I had a a issue with a hiccup or hesitation like the key was turned off then right back on...... other than the hiccup,,, motors runs fine.
I swapped out the CPS and the leaking ICP,,, these two changes helped out dramatically. BUT, I still have a hiccup ever once in a while.
That's why I am asking about the symptoms of a sticky IPR,,,, and how that would affect the motor operation.
got help ? ? ? ?
Tks, Russ
XR-2001 is offline
post #3 of 11 Old 02-02-2011, 06:44 AM
Whats the cps? < having a brain fart
99 psd, 6637 intake, straightpipe, zoodad, aih delete, turbomaster wastegate controller, boost and pyrometer, PHP 6 pos, new forged bottom end from diesel innovations, GT38R, non-EBPV pedistal and turbo outlet, high pressure intake and intercooler boots , Adrenaline Hpop, DIY ccv mod.
stroker342gt is offline
post #4 of 11 Old 02-02-2011, 07:07 AM Thread Starter
CPS-CMP heard em' both called the same thing,, the cam positioner sensor
XR-2001 is offline
post #5 of 11 Old 02-02-2011, 07:17 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
how many miles are on the hpop?
and a sticky ipr will result in like unstable idle from letting off the gas or an injector surge when accel. or no or hard starts.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #6 of 11 Old 02-02-2011, 07:30 AM Thread Starter
I got 160k on the truck, original pump.
Could the IPR cause a stumble like I mentioned ? at 1600 rpms and below, it will hesitate or stumble ever so slightly, but pick back up and run fine. Before changing IPR and CPS,,, it did it a lot more frequently. Now 2-3 times a day, I drive approx 50 miles per day back/forth to work.
I had the truck scanend after I changed the IPR and CPS. A CAM code was reflected, but the mechanic said that could have been casued due to me pulling the battery cables off ( I cleaned my terminals while poking around under tha' hood....)
I replaced all three 30amp relays in the main fuse box upon suggestion by the mechanic.
I guess I'll be buy a AE w/ ford bundle in the very near future. I do not have anyone close I know with any diesel knowledge , therfore I am picking up as much as i can.
Thanks Jarrod and others,,, this thing has me ready to start looking at DODGES... I need intervention ! ! !
Russ
XR-2001 is offline
post #7 of 11 Old 02-02-2011, 07:33 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
you will then need to get the icp readings from ae.
or get a dodge, thats the other fix.
ok im seeing two things here.
you replaced the cps and ipr or cps and icp?
Sold
LSP Group Threads
Jarrod B is offline
post #8 of 11 Old 02-02-2011, 07:43 AM Thread Starter
dangit,,,, sorry ... I replaced ICP and CPS..........there's entirely too many freaking abbriveated parts on these things...
and apparently i have CRS ,,can't remember s**t anymore.
RB
XR-2001 is offline
post #9 of 11 Old 10-12-2013, 09:07 AM
My edge has a gauge for IPR readings. What's a normal high and low?
scfdr13 is offline
post #10 of 11 Old 10-12-2013, 11:03 AM
blue99stroker's Avatar
Quoted: 258 Post(s)
what cps(cam position sensor) did you put in?
the borg warner cps is known for causing stalling/ intermittent stall when the windhshield wipers are on.
also is your truck hard to start cold or hot? this would be another sign of a bad ipr.
i had a failing ipr and my power was considerably less. start up time was 2-3 seconds longer as well.
getting a dodge wont fix anything my friends have spent more keeping their cummins going than i have on my powerstroke. just a whole new can of worms
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
