loping sparatic idle????? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-30-2011, 04:10 PM Thread Starter
my truck sometimes decides to start loping like it has a cam in it with a massive lobe separation, much like a drag car, sometimes it will shut off randomly, and just doesnt run good durning this time. this issue doesnt seem to have a rhyme or reason to it. oil pressure stays normal, alternator is putting out 14.5v like normal. Does anyone have any insight as to where to start with this issue? Plz help.
99 psd, 6637 intake, straightpipe, zoodad, aih delete, turbomaster wastegate controller, boost and pyrometer, PHP 6 pos, new forged bottom end from diesel innovations, GT38R, non-EBPV pedistal and turbo outlet, high pressure intake and intercooler boots , Adrenaline Hpop, DIY ccv mod.
stroker342gt is offline
post #2 of 8 Old 01-31-2011, 10:24 AM
I have the exact same problem with mine. I am also trying to figure out what is wrong
wegotjs is offline
post #3 of 8 Old 01-31-2011, 09:59 PM
Is it after it has warmed up? Cause when its cold that plays a role in the eractic romps. There have been a few posts but mostly point at cold starts etc..
2000 F250 4x4 Supercab Lariat 7.3
AIS Factory Intake
Straight pipe - 5" tip
195k Running strong
Commute 75miles day @17.2mpg
Camoderek is offline
post #4 of 8 Old 01-31-2011, 10:24 PM
scuffs *****
Tyler's Avatar
Send a message via AIM to Tyler
Sounds like the ICP sensor is going bad. Pull it and check for oil.
Sr. Engineering Tech/OPS Technician @ Your local cable company.
1997 7.3L PSD
| 4" MBRP Exhaust | S&B CAI | Torque Converter Lock-Up Switch | Exhaust Brake | FPR Shim |DB High Torque Starter | 188,000 Miles | Xtreme Daily Tune |
SOLD
2014 Ford Fusion SE
| 1.6 EcoBoost | 6-Speed Manual | The basics and some goodies |
Tyler is offline
post #5 of 8 Old 02-01-2011, 06:10 AM Thread Starter
No not just when its cold, where is the icp sensor?
post #6 of 8 Old 02-01-2011, 08:21 AM
scuffs *****
Tyler's Avatar
Driver's side oil rail towards to radiator. Here is a picture.
1997 7.3L PSD
SOLD
2014 Ford Fusion SE
Tyler is offline
post #7 of 8 Old 02-01-2011, 08:30 AM Thread Starter
I think i put a new one in from ford when i built the motor, what do u mean pull it and check for oil?
post #8 of 8 Old 02-01-2011, 08:53 AM
scuffs *****
Tyler's Avatar
The sensor is a two piece deal. Part of it is screwed into the oil rail, part of it clips into the part that is in the oil rail. Its comes out with the flip of a little clip, and you can see the connector. Inside the ICP sensor you can see 3 prongs, and it should be dry inside there, but usually when an ICP sensor is going bad, they start to leak, and you'll get some oil inside it. That will tell you if it needs replaced or not.
1997 7.3L PSD
SOLD
2014 Ford Fusion SE
Tyler is offline
