HELP! BARELY MADE IT HOME! - Ford Powerstroke Diesel Forum
Old 01-23-2011, 11:01 AM
HEY GUYS. GOT AN 01 F450. BEEN HAVING TROUBLES FOR A WHILE AND TRACED IT TO INJECTORS. JUST SENT MINE OFF TO BEANS DIESEL TO BUILD THEM TO STAGE 1'S ALONG WITH REBURNING MY TS CHIP. GOT THEM BACK GOT EVERYTHING BACK TOGETHER AND MAN THEY WOKE THIS THING UP. STILL ONLY HAD A FEW MILES ON THE TRUCK SINCE THE INSTALL SO I WAS JUST RIDING AROUND EASY TO GET EVERYTHING BACK GOING LIKE IT SHOULD AND I GET A CHECK ENGINE LIGHT AND A SKIP. GOT A LOT WORSE AND BARELY GOT HOME. GOOD BIT OF DIESEL SMOKE. HOOKED UP MY AUTO ENGINUITY AND THIS IS WHAT I GOT P0270 CYL 4 INJECTOR CIRCUIT LOW, P1264 CYL 4 HIGH TO LOW SIDE SHORT, P1274 CYL 4 HIGH TO LOW SIDE OPEN, P2066 P0272 P0278 P0284 # 2 4 6 8 INJECTOR CIRCUIT CONTRIBUTION BALANCE FAULT. I REPLACED THE VALVE COVER GASKETS AND HARNESSES AND GLOW PLUGS WHILE IN THERE ALSO. EVERY DAY DRIVER/WORK TRUCK THAT I NEED IN A BAD WAY. HELP! ANY IDEAS? THANKS!
Old 01-23-2011, 05:07 PM
Are you getting any IPR codes?
