idle problem - Ford Powerstroke Diesel Forum
Old 01-21-2011, 01:08 PM
idle problem
Hey guys my idle problem is back. You can hear the motor going up and down a bit, almost as if you are barely tapping the pedal. The tach will more just a little bit. What could this be? Only thing I think of is sticking ipr but im not a mechanic. Any ideas?
Old 01-21-2011, 01:41 PM
Have you pulled the chip and tried it out?
Old 01-21-2011, 02:32 PM
No It doesnt do it all the time its only on occasion. I can try next time it does it
Old 01-23-2011, 05:18 PM
I know it sounds crazy but check the fuel pedel
Old 02-18-2011, 03:33 PM
Idle seems to be getting worse. It drives fine or the problem is unnoticeable but once you put it back in park you can hear the motor get choppy. What should I check first? I am lost
Old 02-18-2011, 03:48 PM
You got anyone nearby with AE and watch your ICP?
Old 02-18-2011, 03:59 PM
Not that I know. Is there anywhere here I can post and see if anyone nearby could give a hand that has an ae?
Old 02-18-2011, 04:03 PM
I would probably just post it up in the general 7.3 forum, but that is just me. This place doesn't get the traffic...
If I were closer I would do it for you...
Old 02-18-2011, 04:09 PM
Well thanks for the offer I will see what I can find. I was thinking of cleaning the ipr now that its warming up finally and going from there. What else do you suggest?
Old 02-18-2011, 04:18 PM
Its the ICP if i had to guess
