Help with Oil Leak - Ford Powerstroke Diesel Forum
Old 01-17-2011, 03:28 PM
Help with Oil Leak
I have attached a picture showing where I see my oil coming from. When I start the motor I can see it starting to pool . What is this connector and what do I need to do to solve the problem. Is there an O ring in there?
Thanks for the help in advance
Scooter
Old 01-17-2011, 03:52 PM
There was a plug there - right?
It had an O-ring on that plug, so just replace it with a new one and reinstall
Old 01-17-2011, 03:58 PM
Hey thanks or the quick reply... That was not my picture just used it as a reference. I have not removed the connector yet so I assume from what you are saying that there IS an O ring in there. Do you know the name of this connector for getting the correct O ring?
Thanks
Old 01-17-2011, 04:01 PM
There are a couple of plugs, on both sides, for the Hi-Pres oil. I guess one of yours is leaking so, take it out and match-up an O-ring at the supply shop.
Old 01-17-2011, 04:10 PM
Nope not the HPOP.. I have replaced those and they are fine. Just the one I have circled in Green in the picture is where it seems to be leaking from
Old 01-17-2011, 06:11 PM
You misunderstand me,,,, those are the Hi-Pres Rails, built into the heads, and there are several plugs in those rails.
Old 01-18-2011, 12:34 PM
Looks to be where the HPO line connects to drivers side head. I believe the attached link is what you need. Give Bob there a call.
Replacement O-rings for Ford Diesel Engines
