Listen to this cold start see what you think - Ford Powerstroke Diesel Forum
post #1 of 14 Old 01-13-2011, 10:34 AM Thread Starter
angcobra's Avatar
Just got the truck, last night, 25 degrees, truck would not start. Plugged it in all night and this is the start with outside temp 29 degrees. Tell me how this sounds to you. Also, if you know what the device on the passenger side that is buzzing let me know what it is.
This is 2 mins after start, I guess this is the EBPV starting to close?
A few minutes later, the sound was coming and going like every few seconds and then got solid again, EBPV?
This rattle type noise was some 5 or 6 miles down the road, could this be EBPV chattering?
This sound happens at no load or decel, I was concerned it might be rod knocking but it could also be from the broken EBPV sensor tube leaking exhaust?
angcobra is offline
post #2 of 14 Old 01-13-2011, 10:44 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Buzzing was your vacuum pump.
What kinda oil is in the truck?
What was the key on voltage at the cold side of the GPR
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is online now
post #3 of 14 Old 01-13-2011, 10:59 AM Thread Starter
angcobra's Avatar
15W-40 Rotella is what the seller said.
Key off was 12.8 volts to relay,
Key on was 11.8 volts to GP side of relay.
NOTE: I tested the relay several times, it is not working everytime, time to change it.
angcobra is offline
post #4 of 14 Old 01-13-2011, 12:33 PM
merc123's Avatar
Mine sounds like that if I don't plug it in in 20* temps. Haven't plugged it in yet this season.
'00 F350
Mods: Falken Wildpeak MT01, Diamo 17 Karat wheels, Red-head Steering box, Autometer gauges, Tru-Cool #4739 trans cooler, BFxenon HID lights
'03 Mustang GT
Mods: A bunch. -->
merc123 is offline
post #5 of 14 Old 01-13-2011, 03:48 PM
check your block heater cable
my truck sounds like that if i start without being plugged(the rump)
2000 f250
diy intake
4"straight pipe
ccv dumped outside
paulgl26 is offline
post #6 of 14 Old 01-13-2011, 03:53 PM
also change oil and filter,fuel filter
you can unplug the ebpv to see if noise goes away
2000 f250
diy intake
4"straight pipe
ccv dumped outside
paulgl26 is offline
post #7 of 14 Old 01-14-2011, 12:35 AM
Hissing definatley is the back pressure valve. Everything sounded normal there. Mine tends to go on and off when its really cold. Not sure if thats perfect behavior, but its not hurting anything.
Early '99 F-350
- AFE Stage II Intake
- 4" MBRP Stainless Exhaust
- Banks Big Head Wastegate Actuator
- DP Tuner (stock, 40 tow, 60 econ, 80 econ, 120 race)
- Adrenaline HPOP
- Swamps Stage I Injectors
- South Bend Organic Single Plate Clutch
crf250guy is offline
post #8 of 14 Old 01-14-2011, 01:04 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
i like how the vids are for diagnosing purposes
ya first is vac pump. btw theres a glow plug issue but you already know that. the allowable votage is 9-12v tho. i heard how it started up anyway.
second is ebpv closing
third is ebpv as well but should be close or open. not going back and forth.
fourth vid idk. but see if you can pin point it.
and the fifth vid. that aint good but it aint the tube. ive had a broken tube and it doesnt make any noise. just soot under the ac pump.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #9 of 14 Old 01-14-2011, 06:39 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
That 5th one bugs me.... It's not exactly like being there though (the vid) so hard to get the whole "feel" of it but I'll take a shot
An easy thing to do, I'd want take a peek at the converter bolts to be sure they're not loose. I dunno,,,, just a wild-assed guess (maybe it's just because you aimed the camera at the "hump" like that was the source of the noise) but it'd make me feel better to know
NoRalPh is offline
post #10 of 14 Old 01-14-2011, 07:09 AM
scraph's Avatar
Just my 2 cents ... how much better of a cold start do you expect? That sounds just fine. Cold oil is one area of concern. Cold fuel another. Cold injectors another. Cold combustion chamber walls another.
There is every reason during a cold start (and warm-up) for a chamber to either not get fueled, get overfueled, to not combust, or to have a late injection. Also, when you are driving down the highway in 20-something degree air, you are force feeding that cold air into and on the engine that you are trying to warm up. There are so many reasons in cold weather for your truck not to start, to start sluggishly, to start rough, and to run noisily, and to run rough ... I'd be happy with what you've got. You don't need to diagnose why a cold engine sounds cold.
2002 F-250 Lariat Extended Cab Long Bed, 7.3L, Auto, 4x4
- 6" BDS Suspension lift (All spring)
- Driveshaft Specialist 1 piece conversion
- 315/75R16 BFG A/Ts
- DP-Tuner F6
- DIESELSITE CPR Fuel System
- Turbo-Master Wastegate Controller
- Donaldson AIS Intake w/ "Zoodad" and AIH Delete
- MBRP 4" T304 Exhaust
- Coolant filter, Evans NPG+ Coolant, 203* Thermostat and Billet Housing
- Factory Tech Valve Body
- ISSPRO Gauges (Boost, Pyro, Trans)
scraph is offline
