Code P0232, qnd P0603
I have a 99 superduty F-350 with a 7.3 and 173k, 4 inch exhaust, superchips tuner, lifted 6 inches.
I am getting thses 2 codes intermittently. The first is Fuel pump relay DVR Circut fail off. I have had this looked at and they tell me it is fine. The second is Internal CTRL MOD KAM error. This one has shown up since the cold weather, and I have not been able to get any information on this one? Please help. |
if no one chimes in here, i would call autozone, they tell you what it is, and possible causes and solutions
Thank you will do.
The P0603 is a Very common code to see, it just means that the PCM has been pulled or the batteries disconnected at some point. The KAM stands for Keep Alive Memory (RAM I guess) has been wiped.
Nothing to worry about,,,,,, |
Thank you NoRalPh.
I called autozone and they didn't know what that code meant. I put 2 new batteries in it a few months back. The other code they have told me could be that I need a new GP relay. The boy explained it might be that it caused the fuel pump to stop to show a fault because it had excess pressure. Does this sound right? When I test the relay I am getting 12 volts at each post. I had read another post about testing the fuel pump, I opened the drain and turned the key on, the fuel came out with force. Auto and truck diesel also said I had plenty of pressure in the fuel pump. |
