Please Help! - Ford Powerstroke Diesel Forum
Old 01-07-2011, 06:24 AM
Please Help!
Got in my 02 X this morning drove to work no problems. 2 hours later got in it cranked fine and went to get something to eat. When I went back to the truck 30mins later the truck turned over and then it was like the battery died. Would not turn over starter and would click but would not turn over. Please help!!
Old 01-07-2011, 06:30 AM
Update. Truck is back at the house thanks to a fifty dollar rollback ride. Went out to try and crank the truck all the lights came on but the starter will not turn over. 2 new optima red top batterys and new alternator. thanks for the help.
Old 01-07-2011, 11:50 AM
Checked batteries with a vo meter. Both were unhooked and checked 15.96v. I went to the fuse box a checked a fuse and got 14.9v. Is this normal?
Old 01-07-2011, 12:01 PM
Someone please help as this is my only method of transportation.
Thanks,
Old 01-07-2011, 12:03 PM
assistant director
starter might have went bad. voltage seems a little high
Old 01-07-2011, 12:13 PM
Could a short in the starter make the voltage high?
Old 01-07-2011, 02:10 PM
.............BUMP.............
Old 01-07-2011, 02:25 PM
I'd get another meter, I don't think it even possible for an "unhooked" battery to be producing 2.5v/cell. My guess is your meter's way out of spec.
You could have a bad starter, solenoid, battery connection, or grounds that could cause that. Look over the Free stuff first You could also try "rapping" on the starter with a hammer while some one turns the key to start.
You could then pull the starter and put jumper cables on it (kinda Micky Mouse, but if it DID NOT jump and spin you'd know it was bad)
