P1316 and P1294 - Ford Powerstroke Diesel Forum
Old 01-06-2011, 01:32 PM
P1316 and P1294
The 7.3 is down, it started running rough, i went into the bank yesterday and came back out and it was running rough, barely idle, coundnt get it to really move, I went to the gas station and check the codes and fill it up and got a p1316 code, I cleared it and it was still running rough, drove maybe a 1/4 mile and it went away, started it today and it did the same thing this time it didn't go away, and it sounds like and idi, I the boost gauge is showing that it's okay, I did a buzz test and the drivers side injectors sound weak, not half as loud as bank one, got the chip pulled and tested again, it shows a p1294. For it to disappear and reappear I'm assuming the idm is okay, so I'm I right in thinking to look for a short, and look at the connector for the uvc harness outside of the head, and I that's not it look at the uvc itself under the valve cover, but what should I be looking for under the valve cover, and does anyone else have a thought on this
Old 01-06-2011, 02:06 PM
Anyone...anyone.
Old 01-06-2011, 02:29 PM
when I pulled the valve cover the process of changing my gp's I notived my uvc harness was actually sliding apart. I assume from engine vibration and some rough off roading lately with hunting. It actually had come apart far enough to lose connection on some of the gp circuits, but I had not noticed any missing yet. so you could ohm out the glow plugs circuits, if some a bunch of them are bad I would look at uvc harness.
Old 01-06-2011, 06:51 PM
ya and do the under valve cover harness mod
Old 01-07-2011, 02:05 PM
My 2001 7.3 had a similar issue, mine was with bank 1 though, the pins in the connector for #5 injector had spread out, from excess vibration I'm assuming, anyways the buzz test showed #5 was bad, but it was just the pins.
Old 01-08-2011, 02:03 AM
Turned out that the vibration separated the connector on the inside of the VC, international makes a clip to keep them intact.
Old 01-09-2011, 05:58 PM
glad you found it, now I'm kicking myself, had not heard of the under valve cover mod, or the clips, not feeling like tearing it apart right away again.
