need reman stat!!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-23-2010, 06:02 PM Thread Starter
spool up that turbo!!
hollister25073's Avatar
need reman stat!!!
i have an 01 7.3 need an engine and ive been told multiple times that its not worth rebuilding so can anybody give me any help with prices and warranty ect thank you!!!
01 f250 4dr LB 6spd
s&b, cfm+
4in straight pipe
DP tuner
boost pyro and engine oil temp
AIH delete, hpx, frx
05 harleys 8000k's
billet grille and painted shell
17"welds and 35-12.5's toyo mt's
cab lights
southbend con ofe waiting to go in
fresh 7.3 from reviva
SOLD
1995 f150 302 5spd 35's sad sad day
hollister25073 is offline
post #2 of 5 Old 12-23-2010, 07:30 PM
well first of all whats wrong with your motor now? that'd explain alot.
Dietoremain is offline
post #3 of 5 Old 12-23-2010, 09:52 PM Thread Starter
all cylinders low compression no power runs rough has a knock i dont have the numbers on the compression in front of me but a good friend of mine says 99% its just cheaper to to a reman just mainly based on the warranty and such
01 f250 4dr LB 6spd
s&b, cfm+
4in straight pipe
DP tuner
05 harleys 8000k's
cab lights
SOLD
post #4 of 5 Old 12-23-2010, 10:00 PM
Coal Rolling = Posing
Hmm...
I have a block sittin in the shop with less than 1k in it, in machine work.
New pistons, bearings, seals, and rings, maybe another grand.
I doubt you'll find a reman for less than 2k.
chvyrkr is offline
post #5 of 5 Old 12-23-2010, 10:04 PM Thread Starter
machine work up here is not cheap and the life this thing has had it will most likely need lots and like i said im mostly paying for the warranty
01 f250 4dr LB 6spd
s&b, cfm+
4in straight pipe
DP tuner
05 harleys 8000k's
cab lights
SOLD
