HELP brown antifreeze - Ford Powerstroke Diesel Forum
Old 12-23-2010, 12:52 PM
antifreeze is a muddy brown color . antifreeze is blowing out cap . i dont know injector cups? is there a way to tell without pulling heads if so how bad are they to replace. truck runs fine and no power loss
Old 12-23-2010, 12:56 PM
Send a message via Yahoo to harley1rocker Send a message via Skype™ to harley1rocker
sounds like you have water in there.maybe need to get your radiator serviced.
ive seen muddy lookin water in radiators,usaul cause is water.its rust
Old 12-23-2010, 01:05 PM
ok but what is causing the excess pressure? and it was all of a souden sorry for spelling
Old 12-23-2010, 09:38 PM
i think i pin pointed the problem. i was unaware of special antifreeze for ps. so im going to flush and refill and see what happens
Old 12-24-2010, 06:41 AM
Could be bad head gasket allowing positive oil pressure to push engine oil into coolant. That would explain the excess pressure... hope it's not this!
B
Old 12-24-2010, 06:48 AM
sounds like just a dirty radiator that has been neglected , due a good flush and use an extended life coolant when filling again ....dont forget the additive as well
Old 01-09-2011, 10:06 AM
problem solved bad thermostat. and brown water was caused from rust from when the motor sat on a shelf for a couple of years
