AC Clutch Noise / Bearings? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-23-2010, 10:08 AM Thread Starter
SteveKran's Avatar
Send a message via AIM to SteveKran Send a message via Yahoo to SteveKran
Exclamation AC Clutch Noise / Bearings?
Ok....I think I've figured out my noise under the hood. I believe it is the bearings in the AC clutch. Is it possible to replace just the bearings itself, or will I have to go with an all new clutch?
Has anyone ever tackled this problem before?
I'm waiting on a pair of snap ring pliers for I can completely pull the rest of the clutch off the compressor.
Any tips/suggestions?
Thanks
2003 F250 7.3L Fx4
Find me on AIM under S/N SteveKran
Custom Tuned 6 pos chip
MBRP 4" Turbo Back/Muffler MIA
Quadzilla Commander
Tymar Intake
Zoodad
Wicked Wheel
Leveling Kit
Nathan K5LA's/Dual Compressors/Dual 5 gallon tanks/1/2" lines
SteveKran is offline
post #2 of 4 Old 12-23-2010, 12:34 PM Thread Starter
SteveKran's Avatar
Anyone....Bueller?
2003 F250 7.3L Fx4
Quadzilla Commander
Tymar Intake
Zoodad
Wicked Wheel
Leveling Kit
post #3 of 4 Old 12-23-2010, 03:37 PM
BuickLeSabre1960's Avatar
I believe you have to replace the clutch as a unit, I'm not seeing a listing for just the bearing.
1997 F350 with a couple things done to it
If all else fails, immortality can always be assured by spectacular error
BuickLeSabre1960 is offline
post #4 of 4 Old 12-23-2010, 03:52 PM Thread Starter
SteveKran's Avatar
I found the bearing at advance auto....I'm about to go pick one up on my lunch break at work. The bearing itself is $32.....the entire clutch/coil/pulley assembly is $104.
2003 F250 7.3L Fx4
Quadzilla Commander
Tymar Intake
Zoodad
Wicked Wheel
Leveling Kit
