Hey there, I got a 1999, 551000 km's, When under hard acceleration you can feel the truck loose power, and then a clicking-tapping noise starts on the drivers side, it sounds like. Before I did my injectors (yesterday) it would start this and then completely die, injectors were screwed, with the new ones you can just let off and then go again.
About the only thing I haven't replaced on this truck is the HPOP, ICP, and IPR, most of the other sensors I have replaced, MAF, MAT, CPS etc.
Fuel filter is new, fuel pump is new, fuel lines from hpop to heads are new, oil is fresh.
I couldn't find an issue exactly the same as this, but from other things I have read it leads me to HPOP, ICP, or IPR. Is there anyway to narrow this down or anyone have this before? and where is the best place to get ICP and IPR. I don't need another HPOP, as I have another motor I can steal it off if need be.
It will be nice to finally have this thing running flawlessly, finally figured out the starting issue, with shiny new injectors lol
Also what is the best scanner for a 7.3? I'll be searching forums but any help I can get will be appreciated.
