engine stalls help please
I have a 00 f-250 7.3 86,000 miles dp tunes 60econ,60 tow 80 econ egt, fuel press trans temp gauges. i stop to fuel up two weeks ago the truck at idle in park and it just stops. the power is still up the fuel pressure gauge at 55lbs . i try to start it back up and runs fine . well last nite it happen again i stop to take my coat off . put the truck in park and it died but it fired right back up also there was no codes.but in the dp tunes i have no codes 1211,1246,0478 in the programs is it the tunes or cps im lost
Did you check your fuel filter and bowl? Is it all gunky down in there?
new filter and flushed the bowl before it stalled
I'm with bjg8599.
