Starter maybe???????? - Ford Powerstroke Diesel Forum
Old 12-12-2010, 06:17 PM
Yesterday when I went to start my 2001 7.3 as I thought it was starting I let off the key. Turned it off. When I turned it back on and tryed to start it it just clicked one time. Almost like the starter is locked up. The batteries were just replaced in July. If it is not the starter what else could it be?
Thanks for any input, Dean
Old 12-13-2010, 04:46 PM
probably the starter unless your batteries are drained down already.
Old 12-13-2010, 04:49 PM
also, check out TSB 02-19-4. It has a couple starting issues on it. Hope this helps.
Old 12-17-2010, 06:37 PM
Update********
Today I took the cables off the batteries and cleaned them real good. Had the batteries checked and they are in top shape (was replaced in July). Tryed to start it and it does the same thing. It is like the started is locked up. One click and that is it. guess I am going to have to replace the starter or could it be somethiing else?
Thanks again for all the help.
Old 12-18-2010, 06:20 AM
Originally Posted by jd3rdnoah View Post
Update********
Sounds like possible bad selinoid switch . Try lightly tapping starter
with a hammer while someone trys and starts it , may be stuck engaged .
Don't tap to hatrd as starter has permanant magnets that can come loose with to much banging
Old 12-26-2010, 08:05 PM
also try jumping the solenoid with a screwdriver or something and see if it works.
Old 02-03-2011, 10:22 PM
Curious if you found out what the problem was. My 01 just started having the same issues, but it has been 27 degrees below zero, and I would prefer to not freeze off my fingers without having an idea of where to start. Thanks
