7.3 low power bad mileage - Ford Powerstroke Diesel Forum
post #1 of 16 Old 12-11-2010, 10:16 PM Thread Starter
low on power and bad mileage, really noticeable when towing. I have only owned this pickup a month. It does not smoke at all. I used to have a 6.0 and the turbo had a distinct whistle and it had twice the power of this 7.3 the sound of this turbo when boosting is more like a whine whoosh noise, so far I can not find a leak in the intercooler system. My old truck would have a little bit of black smoke when leaving a stop light but not on this one. If anyone has any suggestions I would be happy for input..
bleslie278 is offline
post #2 of 16 Old 12-14-2010, 03:53 PM
ScottyP5947's Avatar
Hard to say with what we're given but a 7.3 feels a lot slower than a 6.0, that's no doubt. How bad is the mileage? Is the truck stock? My stock 7.3 felt way slow when I bought it too, my superchips woke it up a bit, as well as the improved exhaust and intake. I bought it to be a family hauler and sees little towing so my experience is all 'unloaded' - I have never towed stock so I don't know what that is like. I bet it it isn't the 'cant even feel her back there'
type of experience you would hope it is.
Scott
2000 XLT F-250 7.3 Crew Cab Auto w/Transgo shift kit
Zoodad
4" MBRP turbo back exhaust w/muffler
PHP TS chip - 65 tow/80DD/120 race
Stancor relay
Caterpillar ELC coolant
Broken-into door lock mod
6637 filter
285/75/16 Hankook ATM's
2" Rough Country add a leafs all around
In the Driveway:
2000
, chipped! (For the wife)
1995 Ford Mustang 3.8 (
2012 Dodge CCSB 2500 w/Hemi
ScottyP5947 is offline
post #3 of 16 Old 12-16-2010, 03:39 PM
No thoughts?
Zoodad
Stancor relay
6637 filter
In the Driveway:
2000
post #4 of 16 Old 12-16-2010, 03:45 PM
dusted4eva's Avatar
Send a message via MSN to dusted4eva
My 7.3 when it was stock got with stock tires was getting around 12 mpg MT. Now with bigger tires exhaust and intake I'm getting aroud 15 Mt . When I'm pulling around 9000lbs it gets around 11-12 mpg. I have a chip on the way, I'm sure that well help it out. The 6.0 is great engine for pulling and mpg.
2001 7.3 SuperDuty Lariat
AFE Stage II Cold Air Intake
PHP Tunes , Autometer Gauges
Zoodad Mod,
4"SS MBRP Exhaust
ITP Overboost Annihilator
Roada Deco Positive Air Shutoff
NADP Heavy Hauler Transmission
6 liter Trans Cooler
Diesel Site Coolant Filtration System
dusted4eva is offline
post #5 of 16 Old 12-22-2010, 09:03 AM Thread Starter
thanks for the feed back. I think a little of my problem is that i did not realize the 6.0 is so much better (I loved it). I had a problem with my chip and sent it in to get fixed, just got it back so i will try it and check my boost pressure. Does anyone know what boost pressure should be with an edge juice set up?
post #6 of 16 Old 12-22-2010, 09:06 AM
scuffs *****
Tyler's Avatar
Send a message via AIM to Tyler
around 12-15PSI
Sr. Engineering Tech/OPS Technician @ Your local cable company.
1997 7.3L PSD
| 4" MBRP Exhaust | S&B CAI | Torque Converter Lock-Up Switch | Exhaust Brake | FPR Shim |DB High Torque Starter | 188,000 Miles | Xtreme Daily Tune |
SOLD
2014 Ford Fusion SE
| 1.6 EcoBoost | 6-Speed Manual | The basics and some goodies |
Tyler is offline
post #7 of 16 Old 12-23-2010, 08:44 PM Thread Starter
I am getting about 15 psi boost acording to my digital gauge. I am getting very low egt reading around 100 degrees sometimes getting up to 600 but not very often. Put new probe and sent gauge in to get checked and nothing was wrong.....
post #8 of 16 Old 12-26-2010, 11:49 PM
scuffs *****
Tyler's Avatar
What are you getting at idle, cruise, and WOT?
1997 7.3L PSD
SOLD
2014 Ford Fusion SE
Tyler is offline
post #9 of 16 Old 12-26-2010, 11:59 PM
egt's should be at 400-600 cruising and at least 800-1000 WOT. that sounds odd.
Dietoremain is offline
post #10 of 16 Old 12-27-2010, 12:19 AM
scuffs *****
Tyler's Avatar
It will depend on where the EGT probe is mounted. If your probe is mounted "pre-turbo" (exhaust before reaching the turbo charger) you should see temps around 250-325 at idle. At a cruising speed, you should see 600-800. And at wide open throttle, you should see 800-1,000 with no tuner, with a tuner or chip you should see the same temps as mentioned above but your wide open throttle temps should be around 1,000-1,200.
If you probe is "post turbo" (Set in after the turbo charger, for say in the downpipe) Then you'll see like a 130 degree idle temp, and a 300 or less cruising temp, and a 600 or so wide open throttle temp without a chip or tuner. With a tuner you will see around 700.
1997 7.3L PSD
SOLD
2014 Ford Fusion SE
Tyler is offline
