Early 99 won't start - Ford Powerstroke Diesel Forum
Old 12-06-2010, 07:06 AM
Question Early 99 won't start
Truck starts and runs fine cold. But drive a little and turn off won't start back up. Cranks fine batteries good. New fuel filter and fuel pump. No apparant HPOP leaks. Any ideas PLEASE HELP. Need this truck running again.
Old 12-06-2010, 07:08 AM
BOSS LEVEL
Will not crank or will not fire back up?
Old 12-06-2010, 07:14 AM
CPS................
Old 12-06-2010, 09:29 AM
Cranks strong no start. CPS done last year on recall.
Old 12-06-2010, 09:35 AM
Even if it was just done, CPS is where I would start. Cheap, easy and responsible for a pile of different issues...just my .02.
Old 12-06-2010, 10:28 AM
Sounds a like a good starting point. Cps. Thanks a lot
Old 12-06-2010, 10:31 AM
Is one cps better than others or oem good enough?
Old 12-07-2010, 09:59 AM
Well cps tested fine, icp tested fine. Didn't have tools to test hpop pressure. Took it Ford they tested ipr then hpop. Once egine warmed up hpop only putting out 350 psi. Hpop replaced with labor $1288. Thanks for the info guys. To bad it wasn't something cheaper. Along with torque convertor, rotors, calipars and some other repairs and maintainance that's a total of $4400 in two months. Some labor mostly parts. Buyers beware these trucks cost alot to maintain.
Old 12-07-2010, 11:22 AM
Dang dude
Really had my fingers crossed for ya hoping it was something simple like the CPS. So the HPOP was bad?? That's pretty rare.
Did you keep your old one? Should send it away and get it modded
Old 12-07-2010, 05:36 PM
What kind of mod? I have the old Hpop.
Tags
99 7.3 won't start
