HELP!!! 00 7.3L having problems starting when cold. - Ford Powerstroke Diesel Forum
post #1 of 21 Old 12-05-2010, 05:00 AM Thread Starter
Packing4Protection's Avatar
Exclamation HELP!!! 00 7.3L having problems starting when cold.
New to the board folks and looking for some advise. I have 00 7.3l that's having problems starting when ~cold. First of all when I say cold it's not cold outside, 50-70 degrees. I replaced both batteries, new alt, new battery cables, 4 new glow plugs (drivers side). I checked the GPR and it's good.
Here's what happing. I let it sit for 2 days and when I turned the key to Aux. the "wait to start" light comes on as it's suppose to. I noticed the battery cluster gauge goes to ~13 the drops to ~10. When the "wait to start" light goes off I try to start it and it seems like a large draw it taking from the batterys. Very sluggish. With the new equipment this thing should fire right up right?
Now, I plugged it in for 2 days (70 degrees outside) and tried it last night and when turned to Aux. position the battery cluster went to ~13 and didn't drop. "Wait to start light" turned off and she fired up.
My question is why does it fire up once heated and not at a "cold" start. Also, it cranks over fine when I drive it around town.. long as it's warm.
I like doing most repairs myself because I learn from it and can share my experiences with others but I'm far from being a mechanic on diesels. Also, it's easier on the pocketbook.
What am I missing here? I've read things about the PCM, but I have a wait to start light and it seems to be working fine.
My truck has 150k on it.
Any help will be greatly appreciated
Packing4Protection is offline
post #2 of 21 Old 12-09-2010, 04:24 AM
wadmalawjoe's Avatar
Anybody out there with suggestions? I have the same problem
wadmalawjoe is offline
post #3 of 21 Old 12-09-2010, 05:07 AM
Nashotah7's Avatar
Sounds like a bad glow plug relay.
Nashotah7 is offline
post #4 of 21 Old 12-09-2010, 05:21 AM Thread Starter
That's what I thought initially also... but after checking it, it showed to be good. It cycled like it should and turned off after a few minutes.
post #5 of 21 Old 12-23-2010, 12:16 PM
Did you fix problem yet?? I'm having same exact problem
Trey7.3 is offline
post #6 of 21 Old 12-23-2010, 02:29 PM
Troubleshooting GPR & GP's
i would double check the relay with the above posted procedure. even if the outside temp. is not cold a diesel still needs glow plugs on a cold start. if the relay is good, check the UVC harness, connections, and ohm the glow plugs. you could also have a loose connection under the valve cover. after time the connector can come loose.
19558077 is offline
post #7 of 21 Old 12-23-2010, 02:55 PM
I checked everything on mine that it said to. and it still wont start when not plugged in. Im gonna change the Valve cover gaskets next I guess
Trey7.3 is offline
post #8 of 21 Old 12-24-2010, 05:40 AM Thread Starter
No I still haven't narrowed it down. It's a nice 50 degrees today and still had issues cranking this morning. Before starting I cycled the plugs 3x's then tried to crank it over. Seemed like a large draw was being drawn on the batterys. So I stopped and tried again after a few seconds and she fired right up. I noticed some light blue smoke come out the exhaust but nothing out of the normal. I've had my truck unplugged for a few days before I started it, but plugged it back in last night.
I have not perfromed an ohm test on the plugs but I did replace all 4 on the drivers side and the ones I pulled out seemed fine. The GPR tested good but after reading some threads from others I might as well go ahead and replace it with a new one and see what that does. If that don't work then I'll check the other plugs and go from there. Also my ABS light came on a few months ago so I replaced the sensor on the back axle... light is still on. Seems like when it rains it pours on me. Next week I will put on a new GPR and post the results. This ABS light will be my next project. Let me know fi you find anything different on your end as well.
Wishing all a Merry Christmas for I'll be stuck here at work.
post #9 of 21 Old 12-24-2010, 06:06 AM
I changed the GPR already. SO I'm gonna go with new GP's and UVC harness next. Mine doesn't smoke or anything. Just wont run unless I plug it up for a couple hours
Trey7.3 is offline
post #10 of 21 Old 12-24-2010, 06:26 AM
Hamiltonbuilt's Avatar
Glow plug relay wire harness
The harder you work, the luckier you get
You don't have to be the best to start, but you have to start to be the best
'08 F350 powerstroke FX4
Black leather
Captains seats
'96 F250 powerstroke XLT
Hamiltonbuilt is offline
