Turbo removal help - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-29-2010, 02:32 PM Thread Starter
scagle1's Avatar
Turbo removal help
Trying to get the turbo off and have everything loose , darn clamp to the uppipes is seized pretty well. It is totally undone but I can't get to the bottom to pop it loose all the way around. I can get to the nuts on the drivers side to loosen the uppipes but can't even see them on the passenger side. Is there an easy way to do this or am I gonna have to drop the exhaust and all to get to the uppipes to take apart there instead? sorry formthe dumb ? But Internet is down and posting off the phone or would search this out on a big screen. Thanx guys
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #2 of 5 Old 11-29-2010, 02:38 PM
O.I.F. Combat Vet 11B
The clamp on the back of the turbo is your issue? I was able to loosen with socket, then take ratchet off and take a hammer and hit either socket or extension a few time to jar the bolt on the clamp. Just give it a few good whacks and hopefully it will come loose for you. If not, keep whacking Lol
2000 f250 crew cab 4x4 6sp manual, Jim Rosewood 238/100 hybrids, gtp 38r, srp1.1 hpop, DP-Tuner! Driven diesel fuel sys!
269,xxx and counting!!
ju015dd is offline
post #3 of 5 Old 11-29-2010, 02:57 PM
Penetrating fluid will do wonders...PB Blaster
carolinaboy02powerstroke is offline
post #4 of 5 Old 11-29-2010, 03:39 PM
smith7.3's Avatar
x2 on the pb blaster
2002 F250 Lariat Crew Cab 4x4
zoodad
DIY P2818 filter
elc
straight pipe
Gauges -Boost- Tranny Temp - EGT
PHP tunes
smith7.3 is offline
post #5 of 5 Old 11-29-2010, 04:05 PM Thread Starter
scagle1's Avatar
Duh !!! A socket on the nut.... Imagine that !!! Will try that in the AM. Soaked it with lube but it's on there pretty well. Helped a friend last week and we ended up having to take the uppipes loose and one broke at the flange trying to loosen it so was trying to avoid this mishap again. Thanks guys !!
scagle1 is offline
