Help with error codes.... - Ford Powerstroke Diesel Forum
Old 05-04-2006, 12:06 PM
Well I have a 2000 Excursion with Napa filter mod, Magnaflow 4", and Superchips tuner. I have had code # P0603 Int Cntrl Mod KAM error on but it had not kicked the SES light. Today after work the SES light came on. It had the P0603 cade and the following....P0672, P0674, P0676, and P0678 Glow Plug 2,4,6,8 Circuit Failure.....Does andone know what all of these codes mean and a possible fix? Thanks, Ashby.
Old 05-04-2006, 03:52 PM
first of all....is it running poorly and have you had a hard time starting it??
Old 05-04-2006, 04:01 PM
No it's not running any differently.
Old 05-04-2006, 04:07 PM
those codes are for all of your drivers side glow plugs. i would check all the electrical connections very thouroghly, and then measure the resistance of all the glow plugs as described in the tech files. if all this checks out OK, my suspition would be your Glow Plug Controll Module has gone bad. the pinpoint test for this is very long and drawn out so it would be tough for me to talk you through the diag, but im suspecting that is what your problem will end up being.......Marc
Old 05-05-2006, 09:36 AM
I was wondering if the #2,4,6,8 were all on one side. I have read a few posts like mine where the codes were the same. Too bad the pep's never said how they fixed the prob....I'll try to figure it out and post back. Thanks, Ashby.
Old 05-05-2006, 04:24 PM
your truck doesnt have the simple relay system though....the excursions have a module that monitors the systems........just in case some diesel head that deals mainly in pickups trys to help you at all.......Marc
Old 05-05-2006, 05:15 PM
Why would International or Ford do that? It is still the same engine so why not make diagnostics and such the same. Maybe there is a good reason for it, but sometimes I wonder.
Old 05-05-2006, 05:18 PM
it is complicated....they put the module on all green state trucks......(california) and all excursions.....so i would actually say they were more consistant on the excursion than they were on the trucks since all excursions have the same system....lol
Old 05-08-2006, 07:43 AM
Well the harness that goes into the valve cover has 9 wires on the flat plug...
I guess 4 injector 4 glow plug and maybe 1 for the module? What is the best way to diagnose the code on this system?
Old 05-08-2006, 03:50 PM
if you look at the connector itself, there may be 9 wires into it, but there should only be 8 pins......
