oil leak from back of turbo
yesterday i was letting my truck warm up (high of neg 5 the other day) when i looked under it and saw a bunch of oil leaking on the ground. Today i got around to checking it out and it seems to be coming out of the exhaust side of the turbo and gets worse the more it warms up will put up some pics anything will help need to know next step to finding out the the problem is.
thank you |
[IMG][IMG] [/IMG][/IMG]
seal inside the Turbo. Oil feeds up to the bearing........ thru the pedistol, then into the turbo, and back out
I've ordered a rebuild kit from this guy for my OBS.
FORD 7.3 POWERSTROKE TURBO TURBOCHARGER REBUILD KIT - eBay (item 310273982856 end time Dec-01-10 10:33:28 PST) |
first my alternator then this is this a pretty straight forward repair
other than removing the turbo..... The Sd trucks are alot easier to remove the turbo from than the OBS trucks.
wait and see if anyone else chimes in, but I'm 99.9% sure of my diagagnostics...... good luck to ya sir.
can i replace just the gasket on this or should i just do the whole rebuild since i have it out
i would do the whole rebuild while you have it out that way you know everything is good to go. first though you need to pull the intake tube off and make sure your impeller isn't hitting the housing. If it is your probably looking at a new turbo.
I don't know much but when that recently happened to me it was cuz the pedestal o-rings went south. when I would drive oil went everywhere....just a thought.....
