Fuel leak - Ford Powerstroke Diesel Forum
Old 11-25-2010, 02:10 PM
Fuel leak
On my 99 i have a fuel leak up on the fuel bowl. It is coming from the lever that u move to drain the bowl. it seems to be leaking by with it shut. i opened it and shut it again now it is leaking really bad. how do you fix this? thanks
matt
Old 11-25-2010, 03:49 PM
i have 2 places up there that gives me fits one is the spot you are talking about. you can get o rings for. and the other is the filter gaskets some times it seals and some times it dose not. and leaks fuel all down in the valley down the back of the block.
Old 11-25-2010, 04:17 PM
it seems to be leaking by the shut off, there is fuel on the front and back of motor i guess some leaking into the valley and the rest down the drain tube. will new o rings fix that.
Old 11-25-2010, 06:58 PM
yes it does and it takes 30 min
Separator Valve Rebuild
Old 11-25-2010, 07:01 PM
i got all my orings here
my dealership does not sell the orings separate
Replacement O-rings for Ford Diesel Engines
