99 high idle question? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-25-2010, 09:49 AM Thread Starter
just put a 4'' turbo back kit on and i noticed that whenever it goes in high idle it will the rpms stay the same but the exhaust goes from sounded like a 747 to just soundin like a normal powerstroke during high idle. goes back and forth every couple of seconds.. would that mean that the waste gate is closing..my old powerstroke would just stay the whistling mode. didnt know if i just need to upgrade the wastegate or what? any info would help.. thanks
cjenne25 is offline
post #2 of 4 Old 11-25-2010, 10:13 AM
late_99_PSD's Avatar
Quoted: 10 Post(s)
Its probably your EBPV (Exhaust backpresesure valve). It blocks off your exhaust to help warm the truck up faster.
Allen
1999.5 F-350 7.3, six-speed
late_99_PSD is offline
post #3 of 4 Old 11-25-2010, 12:55 PM
Cjcross22's Avatar
Yeah sounds like your EBPV doing work, should be fine.
Could need a cleaning too, check out this thread..
Winter Operation, Hard Starting, Hissing Sound Etc...
-Cory
Y2K
F250 XLT 7.3L ECSB SRW ZF6 4x4
Cjcross22 is offline
post #4 of 4 Old 11-27-2010, 05:21 PM Thread Starter
ok cool.. my only thing is i have never heard a 7.3 do what mine does. goes lope then whistle lope then whistle wont stay at and constant whistle during high idle. then driving down the road it will go in a whistle mode at low speeds and low rpms until it warms up..ill pull the sensor off and clean it and see if it stops.. sensor is in the front top of the motor correct?
cjenne25 is offline
