Replacing Orings in hpop - Ford Powerstroke Diesel Forum
Old 11-23-2010, 05:22 PM
So i have a decent leak in the valley of the motor, and it seems to be coming from the front of the motor, ie the HPOP so i ordered the o ring kit and was wondering if the pump needs to be removed or not?
thanks again
Old 11-29-2010, 11:18 PM
if it is the plug on the back of the pump no you do not need to take it out. that is where mine was leaking.
Old 02-06-2011, 04:39 PM
I replaced the end plug o-ring today. Do the threads on the hpop need to be oil free for the loctite to seal properly? I had the plug out for a while and it was slowly draining, any way to drain it quicker?
