motor swap.. not running right - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-18-2010, 04:53 PM Thread Starter
banchee9655's Avatar
hey guys.. i bought an early 99 powerstroke with a blown motor a few weeks ago. we picked up a 2001 motor, turbo, injectors and everything and swapped it all. we finally have it all back toghether now but it dosent run very good sometimes. this morning it started up fine and drove fine all the way to work with no problem. then i went to start it 2 hrs later and it had an erratic idle.( up and down) and very shakey.so we put a scanner on it and ran a cylinder contribution test and it was saying 1,3,5,7 werent firing. so i took it out and ran the heck out of it for a mile or 2 and it started running right again until i let it idle for a bit then it wasnt bad but you could still tell it was missing a little bit. I havent changed the pcm, idm, or harness. my dad took the valve covers off and looked at all the connections and tested the injectors and all was good. my next guess is the harness bein bad or somethin. bein that the computer is for the smaller injectors and turbo do i need to have it reflashed or get a new one? what about the idm? thx
2002 F-250 XLT ECLB
7.3 powerstroke
6 speed
Leveling kit
Muffler delete
6637 intake
FRX
HPX
AIH delete
Future Mods
Hutch and Harpoon mod
zoodad mod
Guages(egt,boost,trans,fuel,hpop
Dp tuner or TS chip(php or gearheads tunes)
Tint
Double din w/ 10"sub
07 badges
07 front conversion(header panel,Harley headlights,grill,bumper)
08 rear conversion(tailgate,taillights,bumper)
banchee9655 is offline
post #2 of 2 Old 11-19-2010, 04:44 AM
optimus's Avatar
i don't think the early 99 IDM will work properly with the newer injectors. at least thats what i was told. maybe a tech will chime in with more info.
If your not giving your all at everything you do your just slowly failing
MY TRUCKs
2002 F250 crew cab short box 4X4 7.3l
E99 F350 dually PSD 7.3 EDGE EVOLUTION running perfect thanks to and engine from NOTSTOCK
^^^don't run your 7.3 with a bad injector this is the result^^^
optimus is offline
