99 White/Blue Smoke - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-16-2010, 05:45 PM Thread Starter
99 White/Blue Smoke
Hello all,
I have a 99 that blows a bluish white smoke basically all the time. Worse in the mornings but after it warms up its not bad. It does it at an idle. Smells like raw diesel. Just installed remanned injectors. 300 miles ago. Not sure if it smoked before I purchased it not running, a month ago. The only thing I have noticed is a gurgling noise when the ignition is on and the fuel pump is running. You can hear it in the pump and in the fuel bowl. Woud air cause these issues? Any input would be much appreciated. Thanks, in advance.
7.3LPStroke is offline
post #2 of 4 Old 11-16-2010, 06:59 PM
O.I.F. Combat Vet 11B
how many miles, how much blow by you have coming out the oil filler tube with cap off. Little steam or lots of chugging white smoke? Also you might want to run a compression test.
2000 f250 crew cab 4x4 6sp manual, Jim Rosewood 238/100 hybrids, gtp 38r, srp1.1 hpop, DP-Tuner! Driven diesel fuel sys!
269,xxx and counting!!
ju015dd is offline
post #3 of 4 Old 11-17-2010, 04:52 AM Thread Starter
Seems to be chugging a little bit, but when I take the oil fill cap off and turn it over it does not blow of just barely lifts up. Ive been trying to do the compression test but I need the adapter to go down into the gp hole. It has 182,000 miles.
post #4 of 4 Old 11-18-2010, 05:17 PM
I think I have a similar problem. I did injectors hoping to fix it but it didn't. I was wondering if the cam sensor could be the problem? However I'm getting a few codes:
-p1316 injector circuit/idm codes detected
-p1211 icp not controllable -pressure above or below desired
Any help would be appreciated
richard1999 is offline
