taking longer to crank - Ford Powerstroke Diesel Forum
Old 11-08-2010, 03:04 PM
Hey guys heres my question, I just the past couple days I ahve noticed that my truck is turning over more times than normal to start, my truck is a 2001 7.3 with 154000 miles and it has always cranked right up in the first second or two, now it is taking about 5 seconds and it does not matter if it has been pluged in or if I just turned it off and then back on. starter is turning strong and the batteries are strong. Thanks for your help.
Old 11-08-2010, 03:07 PM
Powered by Deez Nuts
where are you located? and is it cold outside?
Old 11-08-2010, 04:10 PM
north georgia, its about 40-68 the past couple days.
Old 11-08-2010, 04:23 PM
On my 97 7.3 it was doing the same thing, starter checked out fine but replaced it anyways, starts on first crank every time now
Old 11-08-2010, 04:48 PM
good to know I will check that out, thanks
Old 11-08-2010, 04:50 PM
Mine's doing the same and has been for a while. Cleaned all battery connections and my starter is 2-3 years old now but considering replacing it with the geared-down one from db electrical. According to what I've read, that'll fix it for sure. Good luck!
Old 11-08-2010, 05:11 PM
I hope that it will be an easy fix like an alte, this truck has been awesome I bought it new in december 2000 and it has been a diehard.
Old 11-08-2010, 05:12 PM
how fast does the geared down spin? my slow cranks came back.
Old 11-08-2010, 05:29 PM
From all the research, the starter from dbelectrical.com puts a smile on everyones face. I don't really know the numbers though!
Old 11-09-2010, 12:49 PM
I was woundering if the glow plugs or the gp relay could make this happen?
