hesitation - Ford Powerstroke Diesel Forum
Old 10-31-2010, 07:43 AM
hesitation
I have a 2001 F250. Back in 2008 I had the cam position sensor replaced during a Ford recall. Recently, the "service soon engine" light will come on and the engine will fall to idle for a few seconds. After the light goes out the engine returns to normal. Also, while accelerating it will hesitate. I went to the dealer, but they want $100 just to check it out. I appreciate any ideas to fix this problem.
Old 10-31-2010, 07:46 AM
Does it only do it while it rains? Or is it all the time? Do you have gauges or a chip?
Old 10-31-2010, 07:48 AM
It happens all the time and I have gauges and a chip.
Old 10-31-2010, 08:15 AM
Well whats your boost doing? Also have you took the chip out and tried to drive it?
Old 10-31-2010, 08:22 AM
I bought the truck used in '05 with the gauges and chip already installed. This is my first diesel truck. The boost shows very little movement and I have not tried to drive it without the chip. The chip is set on high tow because we tow a camper with it.
Old 10-31-2010, 08:34 AM
Is it a superchip? Anyways you may want to unplug the chip and try to drive without.
Old 10-31-2010, 08:35 AM
Also check you uppipes for cracks/leaks
Old 10-31-2010, 08:52 AM
Sorry I'm such a novice. It is a superchip. I'll have to try that, plus check the up pipes. Thanks for all the advice.
Old 10-31-2010, 10:03 AM
Np at all man thats what we do here is help
