HELP! 99 7.3 How to Bleed the Fuel System - Been Scouring the forum for an hour!!! - Ford Powerstroke Diesel Forum
Old 10-16-2010, 08:47 AM
My truck is stuck on the side of the road and i cant find directions on how to bleed the fuel system here or google. If someone could please point me in the right direction or give me a quick run down i would greatly appreciate it.
Thanks
Justin
Old 10-16-2010, 08:58 AM
O.I.F. Combat Vet 11B
did you run her out? I have always just pulled the filter and make sure you put at least 10 gallons in the truck. Keep turning the key on to run the fuel pump till it quits. Should get lots of air and spitting fuel. Just keep draining the bowl till you get nothing but fuel coming into the bowl.
Old 10-16-2010, 09:08 AM
i must have ran it out, my guage still showed a little fuel and i have ran it past that point quite often but best I can figure is that it ran out possibly due to the hill I was parked on before that.
Old 10-16-2010, 12:06 PM
Dont trust your gauge neer 1/8th tank..can be very mis leading,
Like he said though..jsut keep cranking and empty the bowl..itll fire..took me 25min to get my old rig going one day..
Old 10-19-2010, 07:46 PM
Right behind the fuel bowl is a yellow lever. Just turn it open then turn the key on the ignition but dont start it. And youll see fuel pouring out from the bottom.
Old 10-19-2010, 07:55 PM
the fuel system is electric on these trucks. remove the cap and turn the key to on but dont crank and watch the fuel bowl fill up. then turn the key off and put the filter on. then crank.
