Burning Oil...READ. Not o-rings
Ok, so here's the deal...a couple of weeks ago I sold my '03 CTD 3500 Dually(a guy wanted it way more than I did lol) and I've been wanting to do a Cummins swap into a Ford. Well just a few moments before I sold my Dodge I found my truck to swap...'99 F-550 XLT 2wd. 4.88's 7.3 w/ 204K on it, crew cab..nice looking truck. Well, the deal was that a guy in Iraq found the truck online and had his wife go buy it..well, she drives it for a few days and then it starts acting up, she has to have a hauler and they don't want to fool with it so he sells it to try to recoup some of the lost funds. I buy it..it was at a garage in Oklahoma(I'm in NC). I start talking to the garage guys(who rightfullly seem knowledgeable). When it came into their shop it was 8 quarts low on oil(it had just had the oil changed). OK...So I asked them to poke around and see if they could figure out what was wrong with it. Fast forward a bit and they find an injector sensor bad. Fix that...still won't run right. Then they find that it's not getting the right amount of fuel pressure. Drop the tank, clean the filters, replace the fuel pump...truck runs like a champ. I ask about the oil problem..they say it looks fine now.
Last Friday morning I fly out to Dallas, get in a cab and go to Durant(where the truck is). I get there...the truck is in way better shape than I honestly figured it would be. I pay the garage and get some paperwork from the owner's wife and then set out for NC. I stop about 60 miles from the garage and fill up with fuel...figure, what the hell..I better check the oil(truck has not smoked at all). I pull the dipstick out...not registering(****). So 2 stores down is an O'rilleys. I go in, buy a case of rotella. Pour in a gallon..and I'm back on the road. I stop 100 miles later...pour in another gallon of oil. I do this ALL THE WAY HOME! IT TOOK 12 GALLONS OF OIL TO GET HOME! Now..all the while driving back I'm calling all my diesel buddies and picking their brains. "O-rings, Turbo, oil cooler going into radiator". Well, the truck is at the dealership and guess what...it has 3 new injectors..a full set of BRAND NEW O-rings, New under valve cover harness---ALL FROM THE PREVIOUS OWNER. Apparently, someone has already been chasing this demon. It does however have 2 hpop fittings that are slightly leaking(not 12 gallons though). Compression 500 on all cyls. Injectors all testing fine. Injector cups look fine. No nicks on o-rings. ANY IDEAS! |
I have heard of this once before. A friend of mine had it on his 99 F250. He was only using 1 gallon every 400 miles, but what he had going on is he had an injector that was leaking internally. He replaced all the o-rings when he bought it , had all 8 injectors tested, they all passed, truck never smoked abnormally. He replaced all 8 injectors and it fixed it. So since you have 3 "new" injectors I would start by replacing the other 5 that haven't been replaced.
Damn. I guess that I'll be swapping in a set of injectors. For the cost of injectors, I'm thinking of upgrading for a full set of performance injectors...any advice?
beans diesel sells injectors for a good price with 1.5 year warrenty if you want to swap in a cummins why spend the money on injectors?
Been having the same problem on my 2002, almost 1 gal every 100 miles. Didn't show up until I went with a ts chip from the old superchips programmer. No blue smoke and no oil in the fuel. Might be an excuse to upgrade injectors...
UPDATE: PROBLEM IS FIXED!
I bought a set of injectors from Pensacola Injectors($1032) and had the local dealership install them($420ish). I've been driving the truck for a few days now and seeing if it corrected the oil issue. I checked my oil yesterday after 1 tank of fuel(yea, I prob should have checked earlier but I really didn't want to find out that it was still drinking oil lol) JUST BECAUSE THE INJECTORS CHECK OUT GOOD DOESN'T MEAN THEY ARE! Mine checked fine and one was bad. Next issue to work on, 4r100. It doesn't seem to want to stay in certain gears and wants to kick down and then up. Any opinions on PATC? |
I've got an Edge Juice with Attitude($350), I ordered a gauge pillar from ISSPRO, redid all the external lights with LED's(Recon 03-07 Dodge Cab Roof Lights). I'm looking at a DP tuner FX-6 next, after I figure out if it's gonna have to have a transmission or not. If it has to have a trans, I'm debating on doing the ZF-6 over a rebuilt 4r100. Another kickass thing I've found out is that I have a big-8 lug pattern...so does Freightliner. They have direct fit 22.5's.
Looks like a trans is in my future. My torque converter keeps locking and unlocking under throttle. I had codes ran on it and it had a cam sensor code pop up. Went to the ford place, talked to the mechanic that put all the injectors in...he already put a new one in. We rechecked the codes on 2 different machines and she came up clean(minus a door lock trouble code). OK, so things I've done so far... 8 new injectors new fuel pump new cam position sensor new tool box w/ 91 gallon aux tank new RECON LED cab marker lights all new LED lights all around the bed and tail lights SILVERSTAR headlight bulbs(the fancy ones) 2 new batteries fuel tank dropped and cleaned out new injector sensor EDGE juice w/ attitude A-pillar quad gauge pod ISSPRO boost gauge ISSPRO Trans temp gauge ISSPRO EGT probe next up, a 2003 Excursion Limited Swap. Heated leather seats Overhead console center console dash steering column(with all the fancy buttons) door panels wiring to make it all work(ugh) New p.s. pump new steering box.....stupid hydroboost New built 4r100 triple disc torque converter modified pump shift kit 22.5's or regearing(whichever pans out first) |
