No Cruse/ No warm up.... - Ford Powerstroke Diesel Forum
post #1 of 1 Old 10-12-2010, 08:05 PM Thread Starter
99 f250 cruise stopped working around the same time the cold temp warm up mode quit working. does anyone know if there is more than one switch on the clutch pedal? i know it wont start unless the clutch is pressed all the way in but it used to knock out the cruise when it worked as soon as you touched the pedal.....same with knocking the truck out of high rpm ebpv open warm up mode. i know the start block switch is on the master cylinder plunger on the pedal but is there one somewhere else? i feel this could be the cure for both issues if there is a separate switch somewhere. thats the only thing i can figure that can cause both issued to stop working at the same time.
'77Shovelhead is offline
