Glow plug relay
it only reads 10.5v. whats that about? most of my GP's are weak or bad. a couple 40* mornings equals some hard starts now, and it aint even cold yet. i'll be replacing ALL 8 gp's, just not sure what 10.5 volts mean
Where are you reading 10.5v? If it's at the batteries, you either need new batteries or have a bad connection to the batteries.
That means your GPR is shot. Replace that before you change your GP's
I agree that your glowplug relay is probably shot. The best way to check it is to connect your voltmeter across the 2 large terminals and cycle the key. If you get more than .25 volts on the meter then the relay is failed. I usually cycle the key several times to make sure that there is no dead spot in the relay.
i got a deal on a set of 8 plugs, its on the list no matter what. |
guess everyones stumped
replacing the GPR
are they exchangeable? |
If you have 2 large relays right next to one another then one is for the intake heater and the other is the glow plug relay. I was told by my parts manager that they are not interchangeable. Different part numbers. The glow plug relay can be identified as the one that has the brown and yellow wires coming off of one of the large lugs. Also if my memory serves me correctly I thought that all excursions were california emissions. And if that's the case and they have the glow plug module with the 2 large black and green connectors then that is not interchangeable with the relay that you purchased.
thanks for the help. i'll let you know tomorrow. maybe i'll hold onto the solenoid. i may need it. |
i put in the new gpr from carquest 5602426 and it's been working great. it hasn't been starting at below 40 but so far, it's been doing fine. It motors right up on the first crank. The bracket however did fit exactly on but it seem to be dong fine with just one nut.
