Ugh..........
So I still haven't fixed the issues in the other threads I've started. Every diesel shop in the area is 2 weeks out before they can get my truck in the shop. Yesterday it was a balmy 55 degrees when I left work at 6pm here in Missouri. I had to drive across town to band practice. I started the truck and waited a few minutes before I left to build a little heat. It felt like it missed all the way to practice, then home, then to work this morning. If you floored it, it would clear up around 2,300-2,500rpms, about the same time it started making boost. I'm starting to wonder if the guy I got the truck from lied to me about draining the bowl and changing the filter. Could this be caused by water getting through to the motor??? Any ideas???
I was just going through my phone and happened across a video I recorded yesterday that i forgot about. I wish I could post it from my phone. I recorded my truck from a dead stop until the phone quit recording after 15 seconds. I had just hit 40mph at the end of the video. lol. I'm telling you, guys, it's slow. And it's my daily driver so any help is much appreciated.
I guess I'll end up answering my own questions. Any ideas? I pulled the plug off of the MAP sensor to check it out and it seemed clean/new. When I pushed it back on I noticed that it went up onto the MAP sensor plug close to 1/2 an inch farther than where it was when I pulled it off. It feels like part throttle response is better now and it seemed to run a tad better. I got 15.2 mpgs out of it on my 30 mile trip to work this morning instead of 13.6mpg according to the overhead. I've also noticed that it's running alot rougher around 1,500rpms than when I first picked it up. Anything below or above that isn't bad. Especially when it engages overdrive around 1,500rpms. It's like riding a bull when the cruise tries to accelerate at that rpm. Any ideas?
by no means, do i think, i know whats goin on, only advise i'd say, is start with the easy stuff. Make sure fuel tank is atleast 1/2 fuel, and install new fuel filter.
From owning my 1st S/D, a little over a month, i've learned alot, from here and other forums. Use the "search" tab, type in some "causes", and see whats goin on. A good check, and easy to do, is make sure your GP and inj. are within ohms.... |
the red line/wire, going to the turbo, but i'd leave that for now, til more experienced members chime in.
I'm a believer in "preventative" maintenence, a grand later, and now a hobby, i'm digging it. I'd do the gp/inj test, easy to do, if you got a multimeter, takes 10-20 minutes. It'll tell you alot, on whats goin on under the valves. |
Have you checked the filters even though they were "changed" ? Also, attach the video in a text message to your email address, then download it on your computer, then post it up for us to see.
