engine light comes on while going up a hill loaded - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-21-2010, 02:05 AM Thread Starter
I have a 2003 f350 4x4 quad cab dually with 165,000 bone stock, seems that whenever i pull my trailer with my rock crawler up a decent hill the ses light comes on, then the light turns off bout five min afterwards or so... I tried to pull a code from it using my new reader but it said everything was great, no Codes...the trailer and crawlers weight combined is about 6500- 7000 pounds. i would much appreciate your imputs, and yes I did search thanks
USMC 1994-1999 F.A.S.T company 3rd pl.
joeycool00 is offline
post #2 of 8 Old 09-21-2010, 02:49 AM
'Merica
thecaptin's Avatar
Possible Overboost Condition causing SES light to set?
Im a not a 7.3 guy, but i "think" i have heard about this before. Just throwin it out there.
Jay
*04 Lariat CCLB 4x4
449RWHP 8/25/12 Montana
*08 Lariat CCLB 6spd 4x4
"Stock" 229RWHP DPF On
*L99 Lariat ECLB 4x4
305RWHP 6/20/13
*03 Ranger XLT 4x4
4.0 5spd Flatbed Wheeler
Originally Posted by Galaxie View Post
(Government says)Whats good for you is good for all but not good for me. Just like Obamacare and everything else.
thecaptin is offline
post #3 of 8 Old 09-21-2010, 03:50 AM
Chapter Director
psd_va's Avatar
yea im not a 7.3 guy either but a friend of mine had a 7.3 modded and if you worked it a little it would throw a over boost code and then clear it self shortly after
03 F350 6.0 SRW 4X4 lariat
481hp 832tq
8" super lift 385/70r16 Toyo MT's
FatBoy traction bars
Durastroke stg1
intake
MBRP 5" straight pipe
Custom tuned by Vivian "Looney Wild Track"
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
Updated fuel pressure regulator (Blue spring mod)
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
post #4 of 8 Old 09-22-2010, 08:25 AM
I have the same problem when towing my 5th wheel, everthing is fine until I get into several long hills and start shifting out of overdrive the SES light comes on. It may stay for 10 minutes, or may stay on until I make my next stop. Then it stays off until I get into a long pull again. It never comes on any other time, just while pulling hard up long hills. My truck is 02, 7.3, automatic, 4 wheel drive, only mod is 6637 air filter. I can never get any codes because by the time I get it somewhere to have reader plugged in the light is off.
good9682 is offline
post #5 of 8 Old 09-22-2010, 08:33 AM Thread Starter
yeah I ended up throwing my reader in my arm rest storage so when it does happen again I can plug that thing in pronto!
post #6 of 8 Old 09-22-2010, 08:36 AM
can plug the reader in while the truck is running? Once I shut the thing off and turn the key on the light is off.
good9682 is offline
post #7 of 8 Old 09-22-2010, 08:51 AM
troid123's Avatar
Send a message via AIM to troid123
It doesnt matter if the SES light goes back off. The code is still stored. You will be able to read it regardless of the light being on or off if you are using a quality code reader. The ones they use at oreilly's,napa, auto zone, etc... do not work for these powerstrokes..
2006 F250 CC Short Bed King Ranch 4x4 (109,000 miles)
4" Turbo Back w/ 6" Tip
SCT x3 w/ Custom Tunes From DJ's/Innovative
03 turbo
Eclipse Navigation/DVD/CD/MP3 w/ Rear Camera
Rear DVD/MP3/CD Entertainment System
Escort Passport SR7 Built In Radar Detection System
K & N Cold Air Intake w/ S&B Replacement Filter
Roll-N-Lock Retractable Bed Cover
Nitto Trail Grappler LT295/70R18
***SOLD 10/31/11***
New Truck:
2011 Ford F-150 Limited 6.2L Super Crew
troid123 is offline
post #8 of 8 Old 09-22-2010, 09:01 AM
what kind of reader do I need to look for, I called local Ford dealer, service manager told the light had to be for them to get any codes (not surprised). If I know what kind of reader to look I can call around and ask.
good9682 is offline
