Inj Buzz test P1277 - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-20-2010, 07:17 AM Thread Starter
Inj Buzz test P1277
My 02 7.3 is running rough and missing with the engin light on. ran the injector buzz test and it came up with P1277. I checked the harness connection on the outside of the valve cover and it looked fine but could it still be burnt up on the inside or is the #7 injector bad. Sometimes when running down the road the light goes off and runs fine untill i put my foot into it. any help would be appreciated.
95 Powerstroke 5 speed regular cab 4x4 W/bale spike bed, strait pipe, front bumper.
06 Powerstroke, 4 door, short bed, auto, 4x4, lariat, strait pipe, Banks six gun.
99 f-350 W/02 engine 6 speed 4D, 4x4, bale spike bed, Alcoa aluminum wheels, 4 inch TB strait pipe, BDP stage 2 injectors, ts 6 position chip, diy intake, autometer boost/pyro, boost fooler
bore355 is offline
post #2 of 3 Old 09-22-2010, 05:07 PM
Just got done with one just like it. The light comes on under load to tell you there is a injector problem. You may have already been told that the 7.3 is notorious for the valve cover gaskets losing connection through them. The high heat and then cooling causes a lot of expanding and contracting so any gap causes an open. And it can't be seen by any means. Unless you have just replaced the gaskets, i would try and change those first. Then look at the injectors next. If you need the gaskets, I found a set at NAPA cheaper than even International could sell them.
bbird121484 is offline
post #3 of 3 Old 09-22-2010, 05:12 PM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 3 Post(s)
02 models dont burn the harness like the obs trucks did , remove the passenger side valve cover and what you will find is that its loose under there
ITS STOCK
SCUFFY828 is offline
