stutter at low throttle - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-09-2010, 07:35 AM Thread Starter
Question stutter at low throttle
I have a 99 f350 7.3 has 187000 and fresh rebuilt tranny. I did have a tune but tranny guy flashed pcm not sure why but now i'm back to stock and besides that over last month my truck idles rough and stutters at low throttle. I have changed the oil twice and each time the problem clears up for maybe 200 miles or so then it comes back does anybody have any clue what might be going on. I had the truck scanned warm and cold and got no codes, passed buzz test, and good compression.
dg7.3 is offline
post #2 of 4 Old 09-13-2010, 11:48 AM Thread Starter
anybody got any ideas 47 views could use some replies now
dg7.3 is offline
post #3 of 4 Old 09-13-2010, 11:58 AM
ICP sensor ?
RRSA is offline
post #4 of 4 Old 09-13-2010, 09:51 PM
1. unplug icp and see if engines smooths out. if so change icp with know good one. also check for oil in connector when unplugged.. if it has oil it needs to be changed. buy from international not ford. or look on ebay. i ve been giving $100 for them there. ford list for over $300.
2. what type of scanner.
3. do you perform cylinder contribution test? results?
4. wiggle all the wiring connections. see if you get any change in idle. check harness going in under valve cover.
ive got a customers truck that has an rough idle issue. had an icp code, unplugged it truck idles alot better. i had an extra, new icp and changed it and problem still exsists. will pull one off of another running truck of mine tomorrow just to make sure i dont have "bad" new one. his truck cranks and idles good for about 10-15 seconds and starts to idle rough. this truck has no codes now, passed the buzz test but shows 3 cylinders on the contibution test. 1,7,8. im gonna check into the idm tomorrow and probably pull the valve covers just to make sure of the harness and connections. will put a set of the wedges in there while im there if every thing checks out ok. his truck clears up alot when it gets above 1000 rpm but still doesn,t run quite right.
00 F350 super crew lariat 326k and still pullin (sold)
03 F250 4x4 ccsb lariat 290k and going strong
4" rough country
dp 5 pos tunes s b air box
4" stright thru exhaust
35/12.50-18 fierce attitude mt's with incubus wheels
tri pillar gauges
95 F450 xlt extra long wheel base
dacco tri disc billet converter (project service truck)244k
00 F350 super crew xlt (future project)
needs engine rebuild
220k
arduece is offline
