Help diagnosing AE codes - Ford Powerstroke Diesel Forum
post #1 of 11 Old 09-08-2010, 12:33 PM Thread Starter
I have a 2001 van with a Powerstroke. I have recently had some trouble with very rough running and even at times it won't even start. I got an AE scan tool and these are the results I got. I've worked on Cummins engines quite a bit, but I'm new to the Powerstroke and I would appreciate some help.
The injector buzz test seemed normal to me. All of the injectors made the same noise.
P1294 injector high side open-bank 2
P1670 electronic feedback signal not detected
P1316 injector driver module codes detected
Cylinder Contribution Tests
1st time P0263 cylinder 1 injector circuit contribution/balance fault
2nd time P0278 cylinder 6 injector circuit contribution/balance fault
The common theme here is that there is something going on with the injectors. I just don't know enough to decide based on these results if it is just a bad injector, a bad sensor somewhere, or a fuel pump/pressure issue.
shoffs30 is offline
post #2 of 11 Old 09-08-2010, 04:41 PM
Powerstroke Techie
forddieseldoctor's Avatar
What codes did you get on your buzz test? The 1294 means that you have an issue with the power circuit to your left hand bank of injectors from the idm (injector driver module) pink/yellow wire. The 1670 means that the idm is not receiving a signal from the injectors that they fired. The 1316 means that there are idm codes but you need to run a buzz test to retrieve them. I would be looking at the uvc (under valve cover) harness on the left bank.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #3 of 11 Old 09-08-2010, 05:11 PM Thread Starter
I did a bunch of searching and I think it is the uvch too. I'm going to look at that and see if it fixes it. I'll run the scan over again and see what codes come up during the buzz test.
shoffs30 is offline
post #4 of 11 Old 09-14-2010, 06:49 PM Thread Starter
I was able to remove the drivers side valve cover and look at the harness. It was noticeably loose. I pushed it in all the way and used a quarter to shim the plug. I ran the diagnostic tests again and it appears that things have changed, but I still have something wrong.
No Diagnostic Trouble Codes Present
P0278 Cylinder 6 Injector Circuit Continuity/Balance Fault
KOEO and Injector Buzz Tests
P1272 Cylinder #2 High to Low Side Open
P1276 Cylinder #6 High to Low Side Open
P1278 Cylinder #8 High to Low Side Open
Switch Test
P1536 Parking Brake Switch Circuit
P0220 Throttle/Pedal Position Sensor/Switch B Circuit
P1780 Transmission Control Switch(O/D Cancel) Circuit Out of Self Test Range
P0571 Cruise Control/Brake Switch A Circuit
P0703 Torque Converter/Brake Switch B Circuit
P0565 Cruise Control On Signal
The Switch Test results are the same as the first time. I just did not include them in my first post. Do I have another problem on my hands with all those codes? Also, I don't have cruise right now, but I would like to add it. What is the best way to add cruise control at this point? Thanks
shoffs30 is offline
post #5 of 11 Old 09-15-2010, 05:13 PM
Powerstroke Techie
Cyl 2,6, and 8 are on the driver's side. It sounds like you have an issue with the valve cover and uvc harness. I would replace them and retest. If you really wanted to you could swap the harness and valve cover from the other side.
Meet Double Aught
2000 F250
post #6 of 11 Old 10-06-2010, 04:48 PM Thread Starter
Last week I replaced the driver's side valve cover gasket and uvch. I cleared all the old codes and test drove it for a day. By the end of the day it was already acting up again. It still dies and runs roughly on an intermittent basis. I ran all the diagnostics again and I only have one code now.
What do you think this means? I appreciate the help. I really want to get my van running right!
shoffs30 is offline
post #7 of 11 Old 10-06-2010, 06:03 PM
optimus's Avatar
looks like the #6 showed problems in all your tests and with the new harness it's still acting up i would replace the injector
If your not giving your all at everything you do your just slowly failing
MY TRUCKs
2002 F250 crew cab short box 4X4 7.3l
E99 F350 dually PSD 7.3 EDGE EVOLUTION running perfect thanks to and engine from NOTSTOCK
^^^don't run your 7.3 with a bad injector this is the result^^^
optimus is offline
post #8 of 11 Old 11-04-2010, 05:43 PM Thread Starter
Time for an update.
I continued to have problems since my last post. I wasn't convinced that it was just the #6 injector so I kept driving it to see if it would really act up again and it eventually did. At that time I ran the diagnostics again.
Long story short, I had all sorts of codes relating to the even numbered injectors (left bank) and IDM codes.
I decided to order a high voltage/freq IDM from Swamps. I put it on last night. When I took my old IDM out I noticed that it was full of water. After I put the new IDM in, the van fired right up and seemed to run pretty well. Much better than it had been at least.
Problem is, I still don't think its running perfectly. I ran the diagnostics this afternoon and I got a whole new set of codes.
KOEO and Buzz Tests
1271,1272,1273,1274,1275,1276- cylinders 1-6 high to low side open
The injectors make the same noise during the Buzz test. They have equal volume and tone.
P0278 cyl 6 injector circuit contribution/balance fault
So basically I still have that same cylinder 6 fault as I always have. Maybe a bad injector?
The weird thing is now I have a problem with the right bank which I never had before. The only change was the new IDM. Any thoughts? I definitely think my old IDM was bad, but does my new one have problems too, or more likely do I still have some other electrical problem.
shoffs30 is offline
post #9 of 11 Old 11-06-2010, 07:01 AM
optimus's Avatar
the #6 needs a new injector as for the new codes the new IDM might have been too much for the wiring harness on the passenger side bank you might also check the wire loom going from the IDM to the valve covers to make sure you don't have a short
MY TRUCKs
optimus is offline
post #10 of 11 Old 02-28-2011, 08:46 AM Thread Starter
UPDATE
I ended up sending the Swamps IDM back because it was still causing problems. I got a new one from them and all the weird codes went away except for cyl 6 contribution. I decided to replace the injector. The code is still present. I've checked the wire for cyl 6 from the IDM to the uvch and it has good continuity. I've had a couple CPS on with no changes. The symptoms while driving is slightly low power and some studdering after the van shifts into overdrive. I don't know where to go from here. I've been working with a Ford mechanic and he is out of ideas too.
shoffs30 is offline
