truck dies in the rain - Ford Powerstroke Diesel Forum
post #1 of 11 Old 09-07-2010, 07:21 AM Thread Starter
kodez's Avatar
I have an 02 with 204000 miles, and recently put a new compressor wheel on my turbo and swapped the exhaust housing for the 38r 1.0 a/r and now my truck doesn't seem to like the rain anymore. It's not sucking water in the intake and all the plugs around the turbo are well away from water and well plugged in.
-Tony
2002 F-350 Lariat
RC / ProComp 6" Lift
DP-Tuner w/Gauge Switch
ITP Overboost Annihilator
Banks Billet Torque Converter
Whistlin Wheel / GT38R 1.0 Housing
On the radio KJ4UVS 73's
kodez is offline
post #2 of 11 Old 09-23-2010, 12:59 PM
make sure you have good grounds, both on the motor(each side of block) and on the fire wall. Water will cause a bad ground resulting in a loss of power to electrical system.
peewee22 is offline
post #3 of 11 Old 09-23-2010, 01:14 PM
MUDSTROKIN''s Avatar
x2 and check for any frayed wires
2005 F250 Reg cab LB XL
Airaid CAI
4" MBRP straight pipe from the turbo back.
RCD EGR Delete
Upgraded Banjo Bolts
Zoodad Mod
Swamps HOT FICM
Lariat Captains Chairs with woodgrain center console
MUDSTROKIN' is offline
post #4 of 11 Old 09-23-2010, 03:03 PM Thread Starter
kodez's Avatar
Hmm ok. Will do. I have owned the truck since 06 and I've never had this problem until recently, I just pulled the turbo out and installed the gt38r 1.0a/r housing and did the whistlin wheel. But I can't imagine that having anything to do with my problem. It is frustrating knowing I have this issue and trying to dodge the rain. Thanks for the advise, ill check it out and post my findings.
-Tony
2002 F-350 Lariat
kodez is offline
post #5 of 11 Old 09-23-2010, 03:05 PM
Now I'm Strokin6.4Liters
Strokin6Liters's Avatar
Feedback Score: 8 reviews
You might have loosened something when you were installing that stuff. I would go back and check anything near where you were working.
2015 CCLB F350 Dually King Ranch - SCT, Flo-Pro, No Limit Fabrication, Recon, Atomic LED, Weathertech, Fuel Offroad, Toyo, Magnum Manufacturing, SouthernLite LED
2008 CCSB F250 FX4 6 Speed - Spartan, KEM, S&B, Diamond Eye, Southbend, Javelina, Ranch Hand, Bilstein, Toyo, XD, N-Fab, Southernlite LED, Recon, Kenwood, JL Audio - SOLD
2005 ECSB F250 - SCT, MBRP, ARP, FCDP, S&B, Autometer, Swamp's, Recon, JL Audio, MTX, Bushwacker, Westin, XD, Toyo - SOLD
Strokin6Liters is offline
post #6 of 11 Old 09-23-2010, 08:11 PM
Have you checked to see if road splash is getting up into your IDM connector, or your PCM connector?
2002 F350 4x4 Crew, coolant filter, 6.0 tranny cooler and ext. filter, pre pump mod & filter, Isspro pillar pod, EV-2 hpop & fuel pressure gauges, AIS, Marinco x2, door seal mod, netbook mount for AE.
bigb56 is offline
post #7 of 11 Old 09-25-2010, 02:39 AM
dumbjarhead's Avatar
had the same problem a few years ago. ended up being a crank sensor. truck didn't like the rain or night.
dumbjarhead is offline
post #8 of 11 Old 09-25-2010, 02:51 AM
correction, camshaft sensor
post #9 of 11 Old 09-25-2010, 04:54 AM
mike 6.0's Avatar
I also had my 7.3 stall in rain turned out to be camshaft postiion sensor also. Died at light and refire no problem then one day nothing.
mike 6.0 is offline
post #10 of 11 Old 09-25-2010, 06:54 AM
Forgot to mention, there has been a known issue with some Cam position sensors causing poor engine performance when the windshield wipers are on. Sounds crazy but apparantley the wiper motor can interfere with the signal from the cam sensor.
bigb56 is offline
