hpop filter screen - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-06-2010, 01:02 PM Thread Starter
Question hpop filter screen
what do i need to do to access the filter screen for the hpop
thanks
The Bus is offline
post #2 of 10 Old 09-06-2010, 01:18 PM
take stuff apart...
06 F350 Traded
alwil is offline
post #3 of 10 Old 09-06-2010, 03:51 PM
Remove the IPR, there is an edge filter in there. Is that what you mean?
2002 F350 4x4 Crew, coolant filter, 6.0 tranny cooler and ext. filter, pre pump mod & filter, Isspro pillar pod, EV-2 hpop & fuel pressure gauges, AIS, Marinco x2, door seal mod, netbook mount for AE.
bigb56 is offline
post #4 of 10 Old 09-06-2010, 03:52 PM
azkcr's Avatar
Quoted: 3 Post(s)
Depends on what truck you have??
Ben Conner
LSP Assistant Director
Got every PSD made...
My DD: '13 6.7L with Optimus Prime's wanker still on the exhaust
azkcr is offline
post #5 of 10 Old 09-06-2010, 04:14 PM
well he did post on the 99-03 7.3 forum, but you're right, people would get more help if they's tell us what they got.
bigb56 is offline
post #6 of 10 Old 09-06-2010, 04:17 PM
azkcr's Avatar
Quoted: 3 Post(s)
It's been one of those days..
But you knew where I was coming from.
Ben Conner
azkcr is offline
post #7 of 10 Old 09-07-2010, 08:21 AM Thread Starter
it's an 03, 7.3l reman. eng.
The Bus is offline
post #8 of 10 Old 09-08-2010, 06:21 AM
optimus's Avatar
just curious how difficult is it to remove that edge filter behind the IPR ? and can you clean it and reinstall or will it need to be replaced ? not sure it this is what he is asking about but it would be good info to have.
optimus is offline
post #9 of 10 Old 09-08-2010, 10:40 AM Thread Starter
hpop filter
is there a filter screen at the ipr and in the bottom of the hpop? truck keeps pulling p1211 code and ford can't figure it out so i'm trying to get info on all possible things so i can find it myself.
have earlier post "pulling a hill " or pretty much all threads by "The Bus" that explains everything, ( truck info, problems, whats been done, ect.)
The Bus is offline
post #10 of 10 Old 09-08-2010, 07:21 PM
I was just reading an old thread and it said the 99-03 IPR does not have the edge filter, it is only found on the earlier trucks 95-98. Hopefully someone with more knowledge will show up.
bigb56 is offline
