Pinned but wont go! (Tricky lots of details)
Hey Everyone, new member, but been reading on the site for a while now to figure things out through other peoples troubles.
'01' 2wd F350 7.3L Stock with Auto Trans and Dual rear Recent work - all since problem began, all to solve problem Changed Fuel Filter Changed Air Filter Full Transmission Rebuild (Fall River Ford, MA) based on their recommendation #8 & #3 Injectors replaced based on diesel fuel shop suggestion Checked Wires through Valve Covers to Injectors Twice Details - Truck runs pretty good around town (under 2200 RPM). Get about 15MPG, no rough idle, no knocking, no shaking. If I bury the pedal from a stop or slow role, truck makes it through first fair, flattens out in second, sometimes third & wont shift. Just a complete loss of power and acceleration. If it does shift the trucks shifts hard. Hangs out around 2800 - 3000 RPM Highway, again if I keep it down around 65 mph, so the RPMs stay low 2s the truck runs fair, at least for a couple of hours. If I try 70, i'm lucky to get twenty mins before the truck stops pulling its own weight up a tiny incline. She will shake, start knocking, and lose speed as fast as she can with the pedal buried. I stop losing speed at about 45 - 50 mph. The truck just needs to sit, either at idle or off. Ten mins or so & I can go back to 65 mph driving for hours. On another note, last night I felt as though my temp gauge may not be reading correctly. It stays just below half ALL THE TIME. The gauge does not show any numerical value so I don't know how hot that would be. But when I got home I opened the hood and touched the shock holding the hood. It seemed very hot, everything seemed VERY HOT. Hotter than I would figure to be normal and it was not running well at the time. Maybe a ECT problem or Engine oil Temp Sensor sending bad info to PCM? How would I check that? The check engine light rarely if ever comes on. It wont stay on more than 5 mins unless I hammer on the truck. I did get it plugged into my OBD reader once with it on and received NO CODES. Very discouraging...any suggestions would be greatly appreciated. Thanks Guys - Brenden |
![]() what kind of OBD reader are you using to pull the codes? You need to make sure that it will read manufacturer specific codes my old reader won't pull these on my 7.3 but will on my 6.0. I would get it on a good diagnostic computer that will allow you to monitor the EOT and ECT while driving if you suspect the gauge is inaccurate.. as for the truck studdering under a load i would check the injector drive module and the oil level in the HPOP reservoir right after the problem occurs sounds like the HPOP might be starving for oil or the ICP or IPR could be malfunctioning. a good diagnostic computer will let you monitor these as well. hope this helps |
Check fuel pressure if you can too.
And btw why did they replace injectors #3 and #8? those are the ones you codes on with a grey CPS, aka theres usually nothing wrong with them. Hope you didnt get ripped off on that one. Ouch. |
Ya me too man, guy had a good Diag computer hooked up and said those two were bad. They certainly looked like hell when i pulled them, but they aren't cheap. #3 had a bad O ring near the bottom.
I was given a number of a former head diesel tech in this area that still does work on the side. I'm going to give him a call this weekend and see if he can help me out with the right testing equipment. Thanks for the input |
Sounds like the sending unit in the fuel tank is stopped up. Drop tank, remove white filter assembly with 2 strainers and either clean them out or take the assembly off altogether. I've had 6 trucks in for almost this exact issue and it was the sending unit every time and some times the tanks needed replacement because of flaking or rusting. Check fuel pressure under load and if you see it drop under load to almost nothing you will confirm.
