1999 7.3 diesel swap from 95 truck
i got a 99 f350 and the block cracked from overheating, can i install a 95-97 powerstroke short block and use the heads from the 99 block. thanks any info would help!
Last edited by fullborncowboy; 08-09-2010 at 06:55 PM. Reason: need more viewers to help answer my question |
anything?
There were many changes from the OBS to the superduty 7.3's, I think the heads were one of them. So no, I don't think you can.
yes you can just use all you uper intake and turbo and bloke off the hole was the fuel
pump was that its 3/4 freeze plug but not sure |
oh im not sure on everything
i was hoping on using my heads and all upper parts, i had my heads check out and surfaced and they are ok, just wondering if i could use older short block because it seems harder to find a 99-03 block
If i remember correctly Marty the mod on here used an obs block for his engine build and his truck is a 2001 or 02 with PMR rods. I think he kept the heads of his pmr block and put them on the obs block. I am not 100% sure, but check the 7.3 tech files section and look for his posts. He has some very helpful write ups.
Yes you can.
I took a 97 long block and put it in my 2001. I had to install a freeze plug in the valley and put all my 2001 stuff on it. |
thanks, i was hoping to find somebody that has done it before. Thanks that helps me a lot!
