02 7.3 Wont crank - Ford Powerstroke Diesel Forum
Old 08-07-2010, 08:28 AM
Send a message via AIM to Darby
02 7.3 Wont crank
Wont crank over at all! Didn't plug it in last night so it wouldn't start this morning, was cranking so i plugged it in and came back to the house. Went down after awhile and now it wont crank, i can hear the relay clicking in the fuse panel. Thanks in advance
Old 08-07-2010, 09:17 AM
Johnny Law Brown
check your battery voltage and where are you located I wouldn't think you need to have it plugged in this weather
Old 08-07-2010, 12:26 PM
Starter solenoid, batteries are good. Im near Huntington West Virginia, and its been hard to start unless plugged in, looking into getting a auto ingenuity scanner to find out whats wrong. It wont start unless plugged in every night and its been upper 60's at night here so it should start anyway, has me stumped.
Old 08-10-2010, 03:29 PM
it takes alot of juice to crank these engines. if you have checked the batteries and got above 12volt it still could not have enough juice if the other battery is just a volt low. i know it sounds crazy but its true i see it all the time. try jumping it . As for the plugging up issue you shouldnt have to plug these engines up until temps are below 0 and thats only if your glow plugs are weak. I have never plugged mine up, ever! check your gpr. perhaps your alternator is shot and caused all this. but it really sounds like batteries.
Old 08-10-2010, 05:38 PM
put a new solenoid on the starter and fixed that problem. it has 272,xxx miles on it btw.
