long hot starts
the ipr has been swapped, had it scanned and seemed fine, random rough idle, and hpop swapped.
whats left to check? |
I keep seeing IPR O-rings over and over again on other forums.
Was the IPR swapped with a new one with new O-rings? |
they were not broken and looked fine. and no the rings were not new.
![]() ![]() ![]() If it was a 6.0 I would say HPOS leak. But 7.3 leads me to IPR |
Check your battery voltage after driving it for a while.
An alternator going bad will actually suck power out of the batteries while running, so it could be that. Also, the next step in the line is the CPS. Last edited by Zytek_Fan; 08-07-2010 at 09:21 AM. |
i will try new orings. but what is weird that it is random. not all the time. Quote:
but the crank speed is just as fast if it was starting right up. |
well i changed the cps from one i had left over from the obs. ill see how that does. then this week ill get orings for the ipr.
ok cps didnt improve any.
however, after i placed my order at taco hell, turned the key to on and heard rapid clicking and the dash lights went with it. can a bad relay cause long cranks? |
