hesitation and surging 0603 code tripped - Ford Powerstroke Diesel Forum
Old 08-06-2010, 06:38 PM
I have a stock (other than a 1705 supertuner) 99 late 7.3. My engine is tripping a 0603 KAM error code read on my superchips 1705 tuner. the engine is extremely sensitive to throttle position off Idle and when coasting downhill on the highway with the converter still locked up. Its like a TPS position error or something. its only in the first 1/2 inch of throttle travel, ...it doesnt do it all the time, hot cold doesnt matter.
It does it with the stock program in it and also with either of the superchip tunes installed (toew or performance)...The dealer says I have a chip in it even though its in his hands with the stock program in it.. he hooked up the IDS and CND it.
any Ideas?
Thanks
Patrick
Old 08-19-2010, 06:18 PM
i was hoping to solve my problem by reading your post ! same code.same tuner same truck. the only diffence is at wot it shut down and when i back the petal it picks back up. changing fuel filter first .petal next(1999 F250 4X4 7.3 210000 on the clock)
Old 08-19-2010, 08:02 PM
There is some real talent on the ORG, if you really want some good advice you have to tell these guys more about your trucks. Good luck guys!
