any body know if this is an o ring leak or bad inj need help ASAP
Hi you all i need some insight on this problem 99 -7.3l i have had a intermitten start problem i finally but the bullit and took off the driver side valve cover . I had my wife turn it over and #2 inj is gushing out oil like a water fall right on to the inj hold down bolt & bracket help need answer
I had the same problem with my 2001 7.3. After changing the injector the next one started doing the same thing. I just bought this truck with hi mileage and the oil was real dirty. From reading the the different forums the main cause of this is poor maintance. I replaced all 8 injectors before it was over.
