1997 powerstroke oil leak - Ford Powerstroke Diesel Forum
Old 07-28-2010, 08:49 PM
I have an oil leak on my 1997 ford powerstroke. Took it to the shop...and they pressurewashed it and said that it might be timing cover? I looked and it seems to be up top...near the manifold but not the HPOP... the leak is on the left side and the oil filter was totally soaked when i took it in. They ruled out the oil cooler and filter..said it was coming from up above. I can look down from above (near air conditioning compressor) and see the front oil plug on head. Doesnt seem to be leaking there. There is also a fuel line? going into head, not an oil line...Almost seems like oil is coming out of there..not really sure tho...I was quoted $1500 to changing timing cover gasket...I dont think this is the problem though....If there are any common oil problems that come from the top of this engine that i havent ruled out...could someone please comment.
Thanks,
Mark
Old 07-31-2010, 06:47 AM
Johnny Law Brown
Most generally they leak from the HPOP or the turbo, but they can leak from anywhere, you just have to you alot of brake clean and get in there with a flashlight and root around until you find it most generally the problem with present its self with a little bit of persistence
Old 07-31-2010, 08:21 AM
Tennessee Powerstrokes
Send a message via AIM to crew991
on mine i had the same leak and on the left head behind the alt bracket there is a plug that is in the oil galley,well i am guessin that was what it was well anyway i took it out and the o rings were both cracked and leakin oil around them i took it out and put some rtv on it and it stopped it ya might want to check that
