2000 7.3 x running bad no power an cel on.
drove this morning everything good. get in this afternoon an start an sounds like a cold winter start an run but never gets any better with a cel on. I ran to store got fuel filter, an check oil. Started back up an still same thing? Is there a way I can pull the codes myself? I tried to take it to get checked but wouldn't even pull itself out of drive way. It will rev but very slow
its a constant miss from start up. i cleared the code by removing cables . It missed soon as it started. hardly stays runnin but does. Could a injector have went bad?
my trucks doing the same thing, i replaced the injector harness an still no change.. 3 injectors on the pass side are not working..
i need help tooooooo |
you really need a scan tool that you can look at all of the parameters of the engine before you start changing stuff it really can be anything by the way it sounds from an IPR to a IDM
When i scanned mine said 1,3 injector an all 4 glow plugs are bad all driver side.my harnes came loose under the valve cover. i pluged it back in an shimmed the clamp an good to go now!
When i scanned mine said 1,3 injector an all 4 glow plugs are bad all driver side. |
